Interference w/ two amps.
GoBlue
GoBlue Posts: 30
edited October 2010 in Car Audio & Electronics
Hi, I am installing my stereo, and need help. I have two alpine amps, one mono block and one four channel. When my engine is running and they are both on, I here a terrible buzzing through the speakers. I located the problem, because as soon as I disconnect the ground from the mono block it disappears. Could this be a sign of mediocre distribution blocks, or what? Im almost sure this is a common problem among dual amps, but I dont know what it is. PS: I swapped it from another car and still the same problem.
Ive uploaded pictures to help you better understand my setup, (if they work)
Thanks.
http://i893.photobucket.com/albums/ac136/dirtonthefloor/th_100_4571.jpg?t=1286494376
http://i893.photobucket.com/albums/ac136/dirtonthefloor/th_100_4572.jpg?t=1286494376
Theater:
Pioneer Elite VSX-55TXI
Adcom 555
Acoustic Research AR9 (Latest)
JBL S Center
Definitive Technologies ProCinema 1000 (Surround x2)
JBL PS1400 Sub
Monster 3600 MkII Conditioner
NAD T572 DVD
PS3
Lots of wire
-Looking for a decent Sunfire MK II-
Samsung LNT-4665F
Polk OMW3 - TV Speakers
Vintage:
Pioneer SX-780
Pioneer PLA-45D Turntable
Advent Heritage Speakers
Post edited by GoBlue on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    The pics are tiny so I'll ask;
    Are the grounds for each amp going to the same place?
    You don't have your power cable from battery to amp running on the same side/near your analog cables from your HU right?
    I had that same problem in 2 of my cars, and using one spot as a ground for both amps solved the problem. Make sure it's a nice clean contact IE no rust/paint on the metal surface.
    -Freddy
    Edit: You can ignore me asking if your power cable+rca's are running alongside since you said the buzz goes away when you disconnect one of the grounds. But it's always good to ask anyway ;)
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • GoBlue
    GoBlue Posts: 30
    edited October 2010
    My ground is a 4 gauge mounted to the frame via seat belt bolt, and it goes into a block that Im running 2 8 gauge wires from.
    My power wire, and RCAs are as far away from each other as I could get them, so hopefully thats not it.
    So... Should I ditch the blocks, (because I have one for the power thats the same size, except it has fuses) and run both grounds to the same place, and can I splice the power wires together or something?
    Theater:
    Adcom 555
    JBL S Center
    JBL PS1400 Sub
    NAD T572 DVD
    PS3
    Lots of wire
    Samsung LNT-4665F
    Vintage:
    Pioneer SX-780
  • GoBlue
    GoBlue Posts: 30
    edited October 2010
    Theater:
    Adcom 555
    JBL S Center
    JBL PS1400 Sub
    NAD T572 DVD
    PS3
    Lots of wire
    Samsung LNT-4665F
    Vintage:
    Pioneer SX-780
  • kawizx9r
    edited October 2010
    You've got a dis block for your ground?
    I use one for my power, but I run separate cables for ground.
    Here's an older pic, speakers unhooked to the amp so you can easily see the cables. The ground cables go to a bolt where the seats latch on to.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • GoBlue
    GoBlue Posts: 30
    edited October 2010
    So it sounds like I am not supposed to have this dis block for ground. I thought it was what was supposed to be done, but we will have to see without it.
    Theater:
    Adcom 555
    JBL S Center
    JBL PS1400 Sub
    NAD T572 DVD
    PS3
    Lots of wire
    Samsung LNT-4665F
    Vintage:
    Pioneer SX-780
  • kawizx9r
    edited October 2010
    GoBlue wrote: »
    Never heard of anyone using one, but I don't see why it would be wrong to use one. Who knows, maybe others have success with it but really I don't see how it'd be wrong too since you're still utilizing the same ground for both amps.
    Do you experience buzzing with EITHER amp? Meaning if you disconnect amp 1, amp 2 buzzes and if amp 2 is disconnected, amp 1 buzzes?
    Maybe you should try using different ground locations for each amp if you try my method and it doesn't work.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • GoBlue
    GoBlue Posts: 30
    edited October 2010
    I dont know yet, but Ill give it a shot. This definitely must be a ground thing then, but Just gotta figure it out. Thanks for the info btw.
    Theater:
    Adcom 555
    JBL S Center
    JBL PS1400 Sub
    NAD T572 DVD
    PS3
    Lots of wire
    Samsung LNT-4665F
    Vintage:
    Pioneer SX-780
  • kawizx9r
    edited October 2010
    GoBlue wrote: »
    Heh anytime! Always here to help :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited October 2010
    There is nothing wrong with using a dist block for the ground as long as the ground itself is done 100% correctly.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • kawizx9r
    edited October 2010
    kawizx9r wrote: »
    Didn't say/imply it was wrong to use one but I'm making an educated guess and saying that there's a ground issue that's creating the buzz he's getting. :(
    Edit: Should've asked about the amps. 8gauge is rather small, and I wouldn't use it for any amp that's pushing over 200wrms.
    I personally like to go a gauge bigger than recommended for each of my amps. Power+ground should be the same gauge btw.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • exalted512
    exalted512 Posts: 10,734
    edited October 2010
    Actually, I would say using a distribution block for the ground is the correct way to do it. It's good to have a common ground.
    I would try scraping off the paint and shooting a couple screws through it thought. Your problem is probably the **** seat belt bolt ground you have.
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2010
    I've always given each amp its own ground keeping each ground wire as short as posible. Always seems to work better and I've yet to have any ground associated noise issues.
  • TakeTheTime
    TakeTheTime Posts: 249
    edited October 2010
    I have three amps, two of them has dis. blocks for both power and ground,
    the two ground cables from the amps are pretty 'long' compared to be ground
    cables, and they're 8G - pretty thin. The common cable from the block to the
    backseat belt bolt is 4G, and I also have two fans wired to this, so it's all two
    2-channel amps and two fans to the same cable, and the subwoofer has it's
    own 0G cable to the same spot - I haven't had ANY trouble with this...
    Sorry 'bout a very long unnecassary post. :(
    But doesn't your Alpine amps get a
    little hot under those backseats?
    Pioneer P88RS-II | Polk Audio SR5250 | JL Audio 12w6v2 | 2x Genesis 3 Stereo 100 | Genesis 3 Monoblock
  • KaosTsoc
    KaosTsoc Posts: 372
    edited October 2010
    I have always run my grounds to the same spot with out using a dist block. Each time I have done this my self, I pick a place on the car and either put a self tapping screw into the sheet metal, also making sure that I have a sold connect (no paint etc), or I find a random bolt (not the seat belt bolt) remove it grind the area down til I see silver, and put it there. I would do the second option if you dont want to make a hole. Hope this helps.
    Thanks.
    2006 Prerunner Access Cab
    5 Speed 4 cycl 2wd
    Audio:
    Pioneer P860 Head Unit
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
    Kinetik HC2000 battery and Sleeve
    200 Amp Mean Green High Output Alternator
    Need a DJ, photobooth, or both for rent?
    http://photoboothdallas.org
