Looking for a 1000 watt amp stable at 1 ohm.
pv15go17
I just bought a Rockford Fosgate T1 15" dual voice coil at 2 ohms and I want to hook it up in parallel so I'm looking for an amp around 1000 watts that is stable at 1 ohm. My brother has the Kenwood KAC-9104d mono amp that has the right amount of power but is not stable at 1 ohm and overheats and shuts off. So I don't want that to happen.
I know the good brands are Rockford Fosgate, MTX, Alpine, Kenwood, etc.
Thanks for any help.
Post edited by pv15go17 on
I'd look for the ooooold Rockford Fosgate amps, highly underrated and very capable of putting out power at 1ohm loads (can't recall the series per-se).
That 9104D is just enough to push a single Alpine Type-R sub, nowhere near enough for what you're asking of it.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk PA1200.1polkaudio sound quality competitor since 2005
Also this is not the 2010 model. It's the model before.
I have that Kenwood amp & drive a dual voice coil setup into one ohm all day long, no issues. Sure you don't have a power supply issue?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
The 900 watt Kenwood amp? But I'm not sure if it is a power supply issue. The amp just shuts off after a couple minutes of playing. But it has plenty of power and should be able to support the t1. So i don't really know what the problem is.
JL Audio 1000 slashV2. I picked one up on ebay for $460.Denon 3806 Receiver
Denon 3910 DVD
Oppo BDP-83 Blu-Ray
Outlaw 7500 300w x 5 @4 Ohms Amp
58" Panasonic 800U 1080P Plasma TV
SVS PB-12 Plus Sub
Lsi25 Fronts-Cherry
LsiC Center
LsiFX Surrounds
SMS-1 Velo Sub EQ
PBJ Interconnects
Blue Jeans Cables
Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?" -
not 1 ohm stable.
RF T1000 would do perfect.
Polk PA1200.1
I know it's rated to put out 1200 at 1ohms "without a sweat" but does it really?? Can anyone confirm that?
Will it also need a lot of breathing room for ventilation?? More then usuall i mean.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
