Looking for a 1000 watt amp stable at 1 ohm.
pv15go17
pv15go17 Posts: 3
edited October 2010 in Car Audio & Electronics
I just bought a Rockford Fosgate T1 15" dual voice coil at 2 ohms and I want to hook it up in parallel so I'm looking for an amp around 1000 watts that is stable at 1 ohm. My brother has the Kenwood KAC-9104d mono amp that has the right amount of power but is not stable at 1 ohm and overheats and shuts off. So I don't want that to happen.
I know the good brands are Rockford Fosgate, MTX, Alpine, Kenwood, etc.
Thanks for any help.
Post edited by pv15go17 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    I'd look for the ooooold Rockford Fosgate amps, highly underrated and very capable of putting out power at 1ohm loads (can't recall the series per-se).
    That 9104D is just enough to push a single Alpine Type-R sub, nowhere near enough for what you're asking of it.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2010
    Polk PA1200.1
  • pv15go17
    pv15go17 Posts: 3
    edited October 2010
    Also this is not the 2010 model. It's the model before.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2010
    I have that Kenwood amp & drive a dual voice coil setup into one ohm all day long, no issues. Sure you don't have a power supply issue?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • pv15go17
    pv15go17 Posts: 3
    edited October 2010
    The 900 watt Kenwood amp? But I'm not sure if it is a power supply issue. The amp just shuts off after a couple minutes of playing. But it has plenty of power and should be able to support the t1. So i don't really know what the problem is.
  • Marcinko7
    Marcinko7 Posts: 121
    edited October 2010
    JL Audio 1000 slashV2. I picked one up on ebay for $460.
    Denon 3806 Receiver
    Denon 3910 DVD
    Oppo BDP-83 Blu-Ray
    Outlaw 7500 300w x 5 @4 Ohms Amp
    58" Panasonic 800U 1080P Plasma TV
    SVS PB-12 Plus Sub
    Lsi25 Fronts-Cherry
    LsiC Center
    LsiFX Surrounds
    SMS-1 Velo Sub EQ
    PBJ Interconnects
    Blue Jeans Cables
    Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?"
  • exalted512
    exalted512 Posts: 10,734
    edited October 2010
    Marcinko7 wrote: »
    not 1 ohm stable.
    RF T1000 would do perfect.
    -Cody
  • Vital
    Vital Posts: 747
    edited October 2010
    MacLeod wrote: »
    Polk PA1200.1
    I know it's rated to put out 1200 at 1ohms "without a sweat" but does it really?? Can anyone confirm that?
    Will it also need a lot of breathing room for ventilation?? More then usuall i mean.
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
