How much capacitance does your amp have per watt?
    heiney9 Posts: 25,492
    edited October 2010
    nadams wrote: »
    I do see the points of everyone who posted in this thread... I just figured it'd be fun to compare amps with a somewhat arbitrary figure. What I should've detailed is the type of amplifier, and the voltage of the caps. However, pretty much all the ones I've seen have been in the 65vdc range.
    And the point of "today's watts aren't like yesterday's watts" is pretty much what I was trying to convey. You can have a "200wpc" receiver today that doesn't have nearly the cap backing that a 70 or 90wpc receiver did 30 years ago.
    But then there's the thought that (12) 10,000 uF caps are a better solution to the older days of (4) 30,000 uF caps of the same voltage.
  • lanchile
    lanchile Posts: 560
    edited October 2010
    Fongolio wrote: »
    Speaking in very general terms, and primarily solid state, doesn't large capacitance more or less equal larger dynamic headroom?
    Not really! as I said before it is NOT only how much capacitance is in your amp but the desing after the power supply.
    I will put it this way.
    if you have a car filled with a tank of 50 gallons of gasoline and the engine is all out of alignment and some of the wheels are smaller than others....get my point here. :(
    Make it simple...Make it better!
  • lanchile
    lanchile Posts: 560
    edited October 2010
    heiney9 wrote: »
    you got that right! Now we have better caps than before (faster/lower ESR) and the quality is way better than those 40 years ago caps. The only problem is these caps are expensive that is why "NOT" many companies use them. and when you find an amp using these caps....They ask for big bucks. But again.. I have seen amps costing $$$$ and they use cheap caps lol.:rolleyes:
    But again: this is not only for caps...it is everything else too.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Fongolio wrote: »
    Well certainly as ken mentioned the greater the reserve the less likelihood that the supply voltages will drop substantially on demanding transient peaks.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    lanchile wrote: »
    Which caps are you refering to as "expensive"?Most modern electrolytics intended for power supply usage from the likes of Panasonic,CDE,Nichicon and UCC have much lower ESR's then those from many decades ago.
  • lanchile
    lanchile Posts: 560
    edited October 2010
    FTGV wrote: »
    Well I use in my amps Mundorf caps!
  • nadams
    nadams Posts: 5,877
    edited October 2010
    I didn't think that low ESR mattered much in audio caps. I recap computer components as a hobby and side business, and obviously low ESR matters there.
    And yes, I understand that more capacitance does not raise wattage output, it is merely how much backing headroom the output transistors have before they have to rely on the peak output of the transformer for all their power.. Transformers can't react as quickly to power demands as capacitors can.
    Ludicrous gibs!
  • lanchile
    lanchile Posts: 560
    edited October 2010
    nadams wrote: »
    yeap!!! you got it right!;)
  • Fongolio
    Fongolio Posts: 3,516
    edited October 2010
    lanchile wrote: »
    I think you misunderstood my question. I was not speaking in terms of overall output power, only in terms of the role of capacitance in the output stage. Capacitors store energy (amongst other things) that is released on demand. When a music passage has many dynamic peaks and dips in a short period of time larger capacitance (in whatever form) should give the unit the "dynamic headroom" to meet the demand of the music, provided of course there is an ample power supply (transformer) to keep up with the rapid charging and discharging of the capacitors. Correct? I think FTGV understood my query.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • lanchile
    lanchile Posts: 560
    edited October 2010
    Fongolio wrote: »
    Correct! and I am sorry I misunderstood your question.
