How much capacitance does your amp have per watt?
nadams
nadams Posts: 5,877
edited October 2010 in Electronics
Thought this might be interesting to some of the geeky types.
At your rated WPC, how much capacitance have the amp designers allowed per watt?
Pioneer A-77x - 100wpc @ 8; 16,400uf per channel (8200x2); 164uf per watt
Onkyo TX-7000 - 90wpc @ 8; 22,000uf per channel (22000x1); 244uf per watt
I don't know if it's a statistic that can say anything about an amp, but I like numbers and was wondering what other amps have...
Ludicrous gibs!
Post edited by nadams on
    edited October 2010
    My Adcom GFA-555 -200 wpc @8 ohms has, a total capacitance of 60,000uf... so I assume that's 30K per channel.
    More robust amps have even more. Though the Adcom is no slouch for power.
    You can tell it has LARGE caps because it takes over a half a minute to discharge when you turn it off...you'll continue to hear your tunes for quite some time before it finally has no juice left.
    I've seen amps with twice the Adcom's figures or 60K per channel? I'm sure there are even beefier amps!
    High capacitance is a GOOD thing...but merely one of many variables that contribute to a good design. Check out some of the readings that Brock listed in an a past thread.
    cnh
    heiney9 Posts: 25,582
    edited October 2010
    Aleph 30 - 30wpc @ 4 or 8 ohms; 60,000uF per channel (120,000uF total) = 4000uF per watt.
    Did I do the math correctly?
    Edit had the wrong amount of capacitance.
    billbillw Posts: 7,956
    edited October 2010
    heiney9 wrote: »
    Alpeh 30 - 30wpc @ 4 or 8 ohms; 30,000uF per channel = 2000uF per watt.
    I think so. Pass always putts huge amounts of filter caps in their designs.
    My Pass DIY Pearl Phono stage has a whopping 40,000uF per channel, and its output is less than 1 watt. Not sure how to calculate that out.
    I know, apples to oranges comparison.
    One of the larges cap banks I've seen would probably be in the Odyssey Stratos Mono blocks. Each mono has 120,000-180,000uF of capacitance depending on the configuration and power output of 180-200 watts/ch. (that would be up to 900uf/watt)
    Of course, you have to realize, its not all about amount of capacitance. The size of the transformers and the current capability of the output transistors is also very important in determining the power/transient performance of the amp.
  • geebolt
    geebolt Posts: 215
    edited October 2010
    cnh wrote: »
    cnh
    60,000 divided by 200 equals 300uf not 30k. (If I'm figuring right).
    Same specs for my Emotiva XPA-5.
    George
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
    edited October 2010
    Bill I had the wrong figure's the Aleph is 60K uF per channel for a total of 120K uF. Each channel uses (6) 10K caps.
    edited October 2010
    billbillw wrote: »
    The Aleph 60's I'm looking at (mono's) have 120,000 per mono for 60wpc performance.
    I agree 100% with your second point. A great designer will match all 3 parameters for great performance together.
  • megasat16
    megasat16 Posts: 3,521
    edited October 2010
    Guyz....figuring out capacitance is not just the measure of power. In order to check the true storage of the energy (joule) on these capacitor banks, you need to figure out the voltage of the capacitors or the power supply rails voltage.
    Just quoting the capacitance value does not mean a more powerful amp. You can have 1farad 12V or you can have 0.1farad at 1000V. Guess you know what you want now!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • xj4094dg
    xj4094dg Posts: 1,158
    edited October 2010
    Continuous Power Output - Stereo
    220 watts RMS x 2, 20Hz-20kHz, 8W
    385 watts RMS x 2, 20Hz-20kHz, 4W
    385 watts RMS x 2, 20Hz-20kHz, 2W
    Continuous Power Output - Mono
    750 watts RMS, 20Hz-201kHz, 8W
    1000 watts RMS, 20Hz-20kHz, 4W
    Current Capacity
    50 amperes continuous
    90 amperes peak
    AC Power Requirements: 1000 watts
    100,000uF computer-grade capacitors in power supply
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
    edited October 2010
    megasat16 wrote: »
    Point well-taken. But I don't think most posts above really disagree with that. As I read them they say that capacitance is only one factor that needs to be taken into consideration.
    Thanks for elaborating on the others.
    cnh
  • megasat16
    edited October 2010
    Yes and No cnh! No post above mention otherwise. I am just filling in.
    I think it's not as simple as to equate the amps power per watt with the capacitance value. The capacitor banks as energy storage will have enough power reserve for the short term peak power for a brief duration. That's why people generally says the more capacitance means more power in general since it has more reserve for the peak power.
    edited October 2010
    megasat16 wrote: »
    Mega, just giving him the geeky answer he asked for, nothing more nothing less.
    edited October 2010
    megasat16 wrote: »
    Nor should one think that watts or peak amperes or whatever is on the spec sheet means a damn thing in and of itself.
    edited October 2010
    megasat16 wrote: »
    What do you mean by "power"? extra capacitance doesn't increase wattage, as you know. So for those that think 200wpc is "better" than 40wpc when you say "power" in this instance of capacitor charging/discharging you are not talking watts.
  • megasat16
    edited October 2010
    Ok for Geeky answer?
    The amp with 200W/ch that has 10000uF@100V per channel will have more dynamic watts (power) than another amp with 200W/ch that has 10000uF@63V.
    That's why I am saying quoting capacitance along with power output is inaccurate.
    I guess it should make sense what I was trying to say before?
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Class of operation plays a part.ie. because of it's high and constant current draw even at idle, a Class A amplifier will benifit most from large storage capacitance.
  • megasat16
    edited October 2010
    heiney9 wrote: »
    H9...you are making it harder than it should have been.
    Extra Capacitance simply means it can store more energy. But how much more energy depends on what voltage it's storing at.
    What do you mean? :confused:
  • megasat16
    edited October 2010
    FTGV wrote: »
    Very True! In some class amplifiers, you don't need a lot of capacitance at all.
    I guess it's getting complicated trying to comprehend things in lamer terms. :D
    edited October 2010
    megasat16 wrote: »
    You missed my point entirely. Just trying to get you to clarify for those less learned. I understand it completely.
    I guess my point was missed on the caps charge/discharge comment. So nevermind.
  • hoosier21
    hoosier21 Posts: 4,424
    edited October 2010
    my head hurts just reading this thread
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2010
    nadams wrote: »
    More than enough to drive every loudspeaker I've ever owned....and others' as well. Simple.
    I agree with some later comments as it's not just about that single figure. There are other smaller/larger figures, some of which may seem totally meaningless or swing greatly between designs, that also determine how good your amplifier is.
  • cristo
    cristo Posts: 231
    edited October 2010
    Fender Pro Reverb (silverface ~ 1976) 95 uf (the first two 70's are in series so they
    count as 35 uf - that's for the power tubes, then 20 more for the driver, 20 more for
    the 2nd stage tubes and 20 more for the 1st stage). 45 watts, so 2.11 uf/watt
    but the B+ is 360 - 440 volts depending on the stage of amplification.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • megasat16
    edited October 2010
    heiney9 wrote: »
    Ok Brock, I guess I missed what you wanted to say. I shall try to simplify but it's a long shot at best.
    Capacitor banks and sizing depends on the amplifier designs (headroom) and Class.
    We simply can't say the size of the capacitor banks or capacitance to easily equate with watts. Capacitors banks are like water tanks. They can be tall or short (voltage) and fat or slender (capacitance). The ones that can store more energy is the tall and fat one (high voltage and high capacitance).
    So, how does energy storage in Joule relates to the Watts (power)?
    The energy storage there can be related back into Power based on the load resistance (reactance of speakers).
    I think we can get into that who really interested in it?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited October 2010
    Hello,
    It is C=CV, where C (charge in coulombs) equals the capacitance times the operating voltage. A power supply for a vacuum tube circuit is usually much higher in operating voltage than one used in a solid state circuit. The power supply needs to have a sufficient charge to not sag when the peak demand happens. Also, it needs to have a low source impedance and sometimes increasing the capacitance raises the impedance. Like most things audio, it is a question of balancing one factor against another for the best results.
    Cheers, Ken
  • megasat16
    edited October 2010
    Thanks Ken, It's a better explanation than I could think of.
  • nadams
    nadams Posts: 5,877
    edited October 2010
    I do see the points of everyone who posted in this thread... I just figured it'd be fun to compare amps with a somewhat arbitrary figure. What I should've detailed is the type of amplifier, and the voltage of the caps. However, pretty much all the ones I've seen have been in the 65vdc range.
    And the point of "today's watts aren't like yesterday's watts" is pretty much what I was trying to convey. You can have a "200wpc" receiver today that doesn't have nearly the cap backing that a 70 or 90wpc receiver did 30 years ago.
    Ludicrous gibs!
  • Outfitter03
    Outfitter03 Posts: 563
    edited October 2010
    How about 32 megajoules. Now that is a capacitor bank.
    http://www.popularmechanics.com/technology/military/4231461
  • megasat16
    edited October 2010
    Uh no...You can't handle 32 of me! :D
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    If space is at a premium and no room for those large caps (and transformer) then using one these is an option.http://www.toutlehautparleur.com/images/Hypex_UcD/UCD400MPE/Hypex_SMPS400.pdf Since their filtering 100khz and not 120hz the capacitance requirements are substantially reduced.
  • lanchile
    lanchile Posts: 560
    edited October 2010
    nadams wrote: »
    Well, I have build many diy amps. and it is not only how much capacitance your amp is using. it is how low ESR is in those caps. it is better to use small caps like: 3x6,800uf than 1x20,000uf you know those big caps like coke cans lol. usually the small caps are faster and they have low ESR than those big coke cans caps also the quality in the caps is important too. The capacitance it is the reserve of power in an amp. that means if you have enough capacitance in your amp, it will not run out of juice. More capacitance it does NOT mean...more power!!!! I hope I made my self clear.
    and lets see here, if a circuit has a 30vdc and you use a 50vdc cap that is good!!!, but if you want to use an 80vdc cap instead of the 50vdc cap that does not mean it will give you more power, it will only handle more voltage (30vdc more) same thing with those 85* and those at 105* that it just for the temperature only.
    all My 100 watts RMS amps That I build I use Mundorf caps total 20,000uf per channel. and never go for the usual thing like if an amp has 120,000uf per channel at 100watts RMS will be better than one using just 20,000uf per channel. all is in the design and the quality.;)
    Make it simple...Make it better!
  • Fongolio
    Fongolio Posts: 3,516
    edited October 2010
    Speaking in very general terms, and primarily solid state, doesn't large capacitance more or less equal larger dynamic headroom?
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
