LSiC replace with Paradigm CC-690. Impressions.
  • mantis
    mantis Posts: 17,385
    edited October 2010
    jmos wrote: »
    I know this threads a bit old but I am also thinking about replacing my LsiC?
    I finally purchased a higher powered 7 channel PA so my Lsi15's, LsiC and four LsiFX speakers are receiving approx 400w@4ohms.
    This really improved the sound quality over my Onkyo 875 than over my Nad T973 but I do find dialog difficult to understand through the LsiC.
    My room does need acoustic treatment so I will probably do this first.
    I do run the centre 1 to 2 db higher than my fronts and at 80hz, tried running audessey a few times as well.
    My LsiC is sitting on a large cd/dvd type storage unit, should I purchase a proper speaker mount?
    any other tips for improvement?
    I can get a new Paradigm cc690 v4 for half price in oz which is your rrp so seriously considering
    Appreciate any info
    It seems most people have trouble with the LSIC , I really don't understand why. I have Installed many of these center channels and owned it myself. Again proper setup , placement and calibration all play a role in how it performs. Any center channel will not perform well if you don't set it up correctly.
    Buying a different brand center channel I don't think is ever a good idea. If Paradigm center channel is what you are after then I strongly suggest going the entire Paradigm system. Your movie experience will be better timbre matched then not.
    If you have a good sub , the LSIC will work great. If you have good power to it it will work great. I can't say it enough , calibrate and proper placement is key.
    Dan
  • acmf74
    acmf74 Posts: 937
    edited October 2010
    My LSiC sounds OK. It seems that the right speaker is quite louder than the left. Is this by design (crossover)?
  • Face
    Face Posts: 14,340
    edited October 2010
    Yes.
