How do I clean my tube amp?
polkfarmboy
polkfarmboy Posts: 5,703
edited October 2010 in DIY, Mods & Tweaks
Hi guys
I just wanted to know what you guys do to clean your tubes up or if you even need to .My tubes are getting dusty and I'm not sure of what I should use incase I cause harm
Post edited by polkfarmboy on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited October 2010
    Send the amp to Mike's Professional Cleaning Service. I promise I'll send it back to you one day :D
    Good question though...I was wondering that myself.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Face
    Face Posts: 14,340
    edited October 2010
    I've used microfibre cloths before, seemed to work well.
  • Jstas
    Jstas Posts: 14,991
    edited October 2010
    I use canned air and a lint-free or micorfiber cloth.
    Expert Moron Extraordinaire
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2010
    I use a premium Duron paintbrush.
  • polkfarmboy
    edited October 2010
    Ok mike I will send it to you for cleaning
    Gimi your add so I know who to make the enclosed check for $250 out to
  • michaeljhsda2
    edited October 2010
    SOLD!!! Seriously though bro I hope you don't have any more issues with your amp. I like the paintbrush idea which gets into the tight areas.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • polkfarmboy
    edited October 2010
    dorokusai wrote: »
    I like this idea too but I dont know what a duron is although I think I have a brand new china brisstle oil brush floating around in storage
    I wonder if this is the same kind as the duron?
  • dorokusai
    edited October 2010
    It's a paint store....sorry. I would suggest something with very soft bristles, such as squirrel.
    F1nut Posts: 51,887
    edited October 2010
    Run 'em thru the dishwasher.
    Ghetto rock.
  • polkfarmboy
    edited October 2010
    Ghetto rock.
    Ok thanks ...I will post the results of the outcome
    F1nut Posts: 51,887
    edited October 2010
    Take pictures.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2010
    I take my gear outside and hose it off in the drive way.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • polkfarmboy
    edited October 2010
    Well if the dishwasher dont do it then I shall try that too . I have a power washer that might come in handy for the task
    Thanks for all the help
  • headrott
    headrott Posts: 5,496
    edited October 2010
    Ghetto rock.
    Hell, just run the whole amp through with the power on!
    Rock it like a hurricaine!;):D
    Greg
  • dpowell
    dpowell Posts: 3,081
    edited October 2010
    I use my front load washing machine because the HE detergent is more gentle on the tubes than dishwasher detergent. After the spin cycle I immediately power up the amp so that the heat from the tubes dries out the inside.
  • zingo
    zingo Posts: 11,258
    edited October 2010
    Vacuum hose with a brush attachment should remove any dust and junk.
