Finally added a pre-amp...
kevhed72
kevhed72 Posts: 5,139
edited October 2010 in 2 Channel Audio
A Parasound PLD 1100 off of Ebay for a very reasonable price. The difference between a pre and an AVR - greater than what I expected. My music has more impact, depth, and feeling now, as everythiing being run through the AVR sounded much "flatter", if you get my drift :cool:.
ON THE HT side - I re-ran the AVRs MACC with the pre's volume at 10 oclock on the dial....only drawback will be I need to remember to put the pre back to the 10:00 position after listening to music. Also, I just ran the pre-outs on the AVR to the video inputs of the new pre. BESIDES the inconvenience of not having true HT bypass, is there any other issue with this setup? (I really wanted a pre with HT bypass, but I couldnt pass on the price and build quality of the PLD 1100...)
Post edited by kevhed72 on
  • PrazVT
    PrazVT Posts: 1,607
    edited September 2010
    Interesting, I've been wondering what the tangible advantage of a pre was. Does the pre only have analog inputs?
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • kevhed72
    I believe only analog inputs. I believe this particular pre is around 15 years old. From the manual:
    "Each input has the same input sensitivity and impedance and is compatible
    Tuner with any typical analog line level source: DAT, MD, DCC, output of a
    Video Laserdisc or VCR..."
  • chandler9a
    chandler9a Posts: 878
    I've done this with no problems, only difference is the benefit of having better sound for 2 ch.
  • BlueFox
    BlueFox Posts: 15,251
    PrazVT wrote: »
    As with everything, it depends. It is possible to buy a pre-amp that is worse than the AVR pre-amp. It depends on the pre-amp, and the pre-amp in the AVR.
  • PrazVT
    PrazVT Posts: 1,607
    I ask because pre-amps look to be as expensive as full blown avrs with pre-outs. I think you've just muddied the waters for me more ;)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • kevhed72
    PrazVT wrote: »
    I have been pretty successful by researching the heck out of my next upgrade, then keep shopping for a good price on the used market. The most useful info. I find when I pop something into Google usually comes from this forum...:)
  • pearsall001
    pearsall001 Posts: 5,258
    BlueFox wrote: »
    How true...my NAD T765 comes to mind. I sold off my CJ PV14L tube pre along with my Krell SS KAV pre. The NAD was not intimidated at all by the presence of those separates. Two channel still sounds glorious! Not to mention the benefit & flexibility of bass management.
    Toolfan66 Posts: 18,020
    Now you know AVR's SUCK for music!!!
  • pearsall001
    If you say so oh exhalted one!!! :rolleyes:
    tonyb Posts: 33,069
    My B&k avr sounds pretty darn good on 2 channel. Is there better in the way of seperates ? Of coarse there is, but then again when comparing pre-amps,there's always something better too. Just have to decide when good enough is actually good enough for you. If I was to ever go seperates again, a passive pre would be on the short list.
    Thanks!!!!:rolleyes:
    BTW I was just teasing in the first place as I love my Pioneer SC-07 for what it does.. But I still prefer seperates...
    Is it not OK to rib anyone anymore?? Or is that not politically correct now as well??
  • pearsall001
    Of course ribbing is still allowed. Hell, I'm pretty good at it myself! ;) I didn't mean to come off like I was miffed, I knew you were only joshing. It's all in good fun, just ask the guys that post threads about TT. Man ooh man do I have fun with that.
    HEHE!!:p
  • organ
    organ Posts: 4,969
    That's great. Many years ago, I was running a 2ch/HT combo with the same configuration you did. Worked fine and sounded great.
    Enjoy your new pre amp.
  • cienega
    cienega Posts: 85
    edited October 2010
    Changing from a receiver used as a pre to a dedicated preamp was one of the most noticeable improvements I made to my system. I was using a Harmon Kardon 3490 which was no slouch but the Vincent tube pre really made a difference.
    2 channel
    Vandersteen 3a sigs
    McCormick 225
    Vincent SAT-1 tube pre
    Cambridge 650 c
    HSU VTF-15H sub
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2010
    I still cannot get my Yamaha rx v665 to act as a pre. Called many and finally had to go w/ Onkyo p-301 pre. I'm happy that my 2ch is totally seperate from h/t.Still miffed that what was said about avr did not happen.....lw
  • coolsax
    coolsax Posts: 1,826
    edited October 2010
    that's weird you couldn't get it working with your 665, I use 665 as a pre just fine.. you must have gotten a bad one...
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2010
    I'm using mine as a Pre-Pro.....what kind of problems are you having?
