Finally added a pre-amp...
kevhed72
A Parasound PLD 1100 off of Ebay for a very reasonable price. The difference between a pre and an AVR - greater than what I expected. My music has more impact, depth, and feeling now, as everythiing being run through the AVR sounded much "flatter", if you get my drift :cool:.
ON THE HT side - I re-ran the AVRs MACC with the pre's volume at 10 oclock on the dial....only drawback will be I need to remember to put the pre back to the 10:00 position after listening to music. Also, I just ran the pre-outs on the AVR to the video inputs of the new pre. BESIDES the inconvenience of not having true HT bypass, is there any other issue with this setup? (I really wanted a pre with HT bypass, but I couldnt pass on the price and build quality of the PLD 1100...)
Post edited by kevhed72 on
Interesting, I've been wondering what the tangible advantage of a pre was. Does the pre only have analog inputs?Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I believe only analog inputs. I believe this particular pre is around 15 years old. From the manual:
"Each input has the same input sensitivity and impedance and is compatible
Tuner with any typical analog line level source: DAT, MD, DCC, output of a
Video Laserdisc or VCR..." -
I've done this with no problems, only difference is the benefit of having better sound for 2 ch.
As with everything, it depends. It is possible to buy a pre-amp that is worse than the AVR pre-amp. It depends on the pre-amp, and the pre-amp in the AVR.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I ask because pre-amps look to be as expensive as full blown avrs with pre-outs. I think you've just muddied the waters for me more
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
I have been pretty successful by researching the heck out of my next upgrade, then keep shopping for a good price on the used market. The most useful info. I find when I pop something into Google usually comes from this forum...:) -
How true...my NAD T765 comes to mind. I sold off my CJ PV14L tube pre along with my Krell SS KAV pre. The NAD was not intimidated at all by the presence of those separates. Two channel still sounds glorious! Not to mention the benefit & flexibility of bass management. -
Now you know AVR's SUCK for music!!!
TOOLFORLIFEFAN wrote: »Now you know AVR's SUCK for music!!!
If you say so oh exhalted one!!! :rolleyes: -
My B&k avr sounds pretty darn good on 2 channel. Is there better in the way of seperates ? Of coarse there is, but then again when comparing pre-amps,there's always something better too. Just have to decide when good enough is actually good enough for you. If I was to ever go seperates again, a passive pre would be on the short list.HT SYSTEM-
lsi 9's -
pearsall001 wrote: »If you say so oh exhalted one!!! :rolleyes:
Thanks!!!!:rolleyes:
BTW I was just teasing in the first place as I love my Pioneer SC-07 for what it does.. But I still prefer seperates...
Is it not OK to rib anyone anymore?? Or is that not politically correct now as well?? -
TOOLFORLIFEFAN wrote: »Thanks!!!!:rolleyes:
Of course ribbing is still allowed. Hell, I'm pretty good at it myself!
I didn't mean to come off like I was miffed, I knew you were only joshing. It's all in good fun, just ask the guys that post threads about TT. Man ooh man do I have fun with that. -
pearsall001 wrote: »Of course ribbing is still allowed. Hell, I'm pretty good at it myself!
HEHE!!:p -
That's great. Many years ago, I was running a 2ch/HT combo with the same configuration you did. Worked fine and sounded great.
Enjoy your new pre amp. -
Changing from a receiver used as a pre to a dedicated preamp was one of the most noticeable improvements I made to my system. I was using a Harmon Kardon 3490 which was no slouch but the Vincent tube pre really made a difference.2 channel
Vandersteen 3a sigs
McCormick 225
Vincent SAT-1 tube pre
Cambridge 650 c
HSU VTF-15H sub -
I still cannot get my Yamaha rx v665 to act as a pre. Called many and finally had to go w/ Onkyo p-301 pre. I'm happy that my 2ch is totally seperate from h/t.Still miffed that what was said about avr did not happen.....lw2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
that's weird you couldn't get it working with your 665, I use 665 as a pre just fine.. you must have gotten a bad one...Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
leftwinger57 wrote: »I still cannot get my Yamaha rx v665 to act as a pre. Called many and finally had to go w/ Onkyo p-301 pre. I'm happy that my 2ch is totally seperate from h/t.Still miffed that what was said about avr did not happen.....lw
I'm using mine as a Pre-Pro.....what kind of problems are you having?
