What speakers are these?
soccermatt34
soccermatt34 Posts: 6
edited September 2010 in Vintage Speakers
Guy on Craigslist has these for $100, any idea what model they are? Just curious before I consider taking a look and he doesn't seem to know.
Post edited by soccermatt34 on
  • kawizx9r
    kawizx9r Posts: 5,150
    Buy them.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Any sda for $100 is a great deal.
    Might be
    Sda 1c's
    sda 2b's
  • soccermatt34
    haha ok :p I will definitely go check them out since he is local.
  • Fongolio
    Fongolio Posts: 3,516
    They look like SDA-1's from the pics. If they work they are a steal at that price.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • HB27
    HB27 Posts: 1,518
    Run..DON'T walk!
    We'll fill you in later as to how to mod, upgrade, and spend Your money. There's a lot of quality sound headed your way.
    heiney9 Posts: 25,497
    Gold colored Polk Audio emblem is a later model. Probably SDA 2B's or 1C's. At $100 it's a no brainer. If I had to guess based on the photo and proportions in the photo I'd say SDA 2B's.
  • Face
    Face Posts: 14,340
    They look like 2B's.
  • inspiredsports
    inspiredsports Posts: 5,502
    I'm thinking 1987 Walnut 2B's also. That's a pure steal if all of the drivers are working.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    nooshinjohn Posts: 25,998
    Run.... Most definately RUN!
    They could also be 1c's, but either way, 100 bucks for a set of SDA's in that condition is a steal.
  • inspiredsports
    Lasareath wrote: »
    Hopefully he doesn't mean the ones on the top are $100!!!
    Seller's second image cameos the Polk badge. Plus OP came here to CP to ask.
    NAD SS rigs w/mods
    GIK panels
  • fishbones
    fishbones Posts: 947
    If he is talking about the Polks...which we are only assuming since you didn't show us the ad, then you should already be on your way there to buy them!
  • inspiredsports
    Maybe it's all 4 speakers for $100 :eek:
    NAD SS rigs w/mods
    GIK panels
  • geppy1
    geppy1 Posts: 3,076
    Based on the height to width ratio (in the picture) I bet they are 2Bs
  • soccermatt34
    The ad is definitely for the polks, still waiting for the seller to contact me so I can snatch em
  • soccermatt34
    Finally heard back from the seller and just took a quick look at them. They look like they are in perfect condition but we had no way to test them out. I have a Denon 1910, any chance I can power em for a few minutes on that to get a sound check? Seller raised his price to $175 when he realized what he had.
  • inspiredsports
    That's a 7.1 with 90 wpc and a left and right channel would certainly be OK to power then up. Just don't go crazy and drive the to amp a distortion/clipping level. 2B's are very efficient with just 1 tweeter and 2 6.5's mid-woofers per cabinet. You do need to find out if the Denon is COMMON GROUND.
    Do you know if the seller has the interconnect connected between cabinets?
    The reason I ask is that Polk SDA series speakers require a COMMON GROUND amp if the interconnect is connected and I don't know if your Denon is common ground. You can always use a non-common ground amp to test without the interconnect connected, but then only the tweeters and inner speakers are in play, so you would not know for sure if the outer 6.5's are working.
    A test you should perform with the cabinet grilles off (and no power to the speakers) is to gently push in the 12" passive radiator in with your (clean and dry) thumb and 4 fingertips spread in a circular pattern and hold it in for 3 to 5 seconds. As you are pushing in, watch the 2 6.5" mid-woofers expand outwards. Keeping the passive radiator gently pushed in, They should stay out for a moment and then recede back into the cabinet taking a few seconds. Then, gently pushing in and immediately releasing the passive 2 or 3 times, you should be able to see the mid-woofers travel in and out
    Assuming great cosmetic condition, all drivers are working well and the interconnect cable is there, $175 is still not too bad. Buying, (or better yet building a higher quality version) interconnect is about a $35 bill.
    Maybe he will accept $150?
    NAD SS rigs w/mods
    GIK panels
  • soccermatt34
    That's a 7.1 with 90 wpc and a left and right would certainly be OK to power then up. Just don't go crazy and drive the to amp a distortion/clipping level. 2B's are very efficient with just 1 tweeter and 2 6.5's mid-woofers per cabinet.
    The reason I ask is that Polk SDA series speakers require a COMMON GROUND amp if the interconnect is connected and I don't know if your Denon is common ground. You can test without the interconnect, but then only the tweeters and inner speakers are in play, so you would not know for sure if the outer 2 6.5's are working.
    He didn't have the interconnect cable
  • inspiredsports
    ran out of time
    . . . Then, gently pushing in and immediately releasing the passive 2 or 3 times, you should be able to see the mid-woofers travel in and out without hearing any scratchy noises. Noise indicates the voice coil was over-driven at some point or the magnet on back of the driver has come loose and shifted. New drivers (if available) are $48 direct from Polk and a few dollars less on the used market.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    So you are really looking at $210 by the time you buy/make a cable, but it does give you a bargaining point and you are fine to use your amp because the interconnect is not in play and you don't know if the outer drivers work. Raising his price with no way to show they work was probably not the smartest move on the seller's part.
    You will not know if the outer drivers work other than watching them push in and out with no noise which is a start.
    There is a way to just use regular lamp cord, etc. just twisting the ends and inserting them into the interconnect sockets, but you need to know what you are doing there and whether your amp is common ground or not comes into play again.
    I've owned and loved my 2B's since 1987 when I paid a ton for them and I have put about $400 in mods since and enjoy them nearly every day when I'm not listening to other Polk's in the house. $150 should be a good number in today's market.
    NAD SS rigs w/mods
    GIK panels
    Offer him $150 and tell him he's a dick for listing it at one price and then raising it when you came to look at them. $150 is still a very good deal if they are in great shape and work properly.
  • backinthelou
    backinthelou Posts: 36
    A guy here had a listing on CL for different brands but no specific models of what he had. I spoke to him on the phone and he mentioned that he had some Polks that he would take $50 for. At the time, I had no idea of what SDA was. Anyway, I drove about an hour through highway construction and another half hour through the sticks and winding mountain like roads. His address wouldn't even show up on GPS and he had to walk out to the main road to flag me down. Anyway, I get down to his basement and started looking at some KLH monsters(old cheap crap with 15" woofers) that I wanted for garage use. I kinda looked up the Polks before I left the house so I had a little bit of an idea that they were "decent". Immediately he tells me that he had to have $100 for the Polks because he looked it up on the internet and saw that they were going for that(I don't know where he looked, but even $100 is cheap).
    I gave him a rash of crap letting him know it was bullshart that I drove that far and he didn't even call me and waited until I got there to change his mind. He realized he had f-ed up and said, "Well, I guess I can let them go for $50." I got them home and realized they were SDA-2A's-for $50-a bargain to be sure. Long story short, if another pair pops up for $100, don't think about it-just go get them.
    BTW, for a total of $115, I got the Polks, a pair of pristine pair of Utah HS5-A's, a set of Realistic Super Tweeters, a Marantz 2230 and a Pioneer SG-9800 that needs some work.
  • Polkie2009
    Polkie2009 Posts: 3,834
    Unfortunately,it seems that you see a lot of that raising the price bs on CL, good luck to you.
  • Joe08867
    Joe08867 Posts: 3,919
    lasareath wrote: »
    that's why i carry a knife with me at all times!
    +100,000,000
  • djperez81
    djperez81 Posts: 388
    Lasareath wrote: »
    that's why I carry a knife with me at all times![/QUO
    or a gun:D
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • inspiredsports
    Wow! From helping a dude figure out which Polks he's negotiating to buy to knifing and shooting dudes on CL who up prices. You three are really impressive.
    NAD SS rigs w/mods
    GIK panels
  • Joe08867
    It's called Sarcasm!
  • HB27
    HB27 Posts: 1,518
    Joe08867 wrote: »
    Obvioulsy sarcasm and I understand where you're coming from.
    I've had a couple of jerks on CL do that to me and I just want to take a big dump on the driver's seat of their car and Superglue their door locks!
    BTW, Sarcasm again. LOL!
  • phocion
    phocion Posts: 157
    Joe08867 wrote: »
    +100,000,000
    "I heard about your speakers on Craigslist..."
    The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
