Restoring SDA-1c
Valentine
Valentine Posts: 46
edited September 2010 in Vintage Speakers
Hello everyone, I have a pair of sda-1c's and im looking to update or restore them. I wanted to see what everybody thought. I want to replace the tops and bottom with Granite Tops/bottoms, and add a strip down the side like i believe the SRS series have. Do you all think it would look good or should i restore them back to original. I'm not selling them so dont even ask!:). Now, im only 23 so i like the shining blacks and extravegate styles, but im willing to do them original so they hold better value. Just wanted some thoughts on the subject.
Thank you Mitchell
Post edited by Valentine on
  • kawizx9r
    kawizx9r Posts: 5,150
    I'm most positive that if you do a quick search on SDA's you'll find a ton of great stuff!
    First and foremost what others do is replace the stock resistors/caps on the crossover. Replace the SL2000 tweeters with RD0-194's, make sure you have a good seal between cabinet and drivers, and spiking them.
    The rest, all aesthetics so that'll be up to you.
    Kind of miss my 1C's, what style do you have? And what else are you running with them?
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    nooshinjohn Posts: 25,916
    I did the strip down the side and they looked great. When you can, pm me your email and I will forward some pictures to you...
  • Valentine
    Valentine Posts: 46
    Ive done the RDO-194 upgrade . spiked/dynamated/mortile, Haven't touched the crossover yet just replace the polyswitch, Kind of scared to mess with the crossover. Plus i really didn't like the new tweets, but im giving them time to break in.
    Im running them with a Parasound Halo A21/ AQ CV-4 cables
    EndersShadow Posts: 17,704
    Valentine wrote: »
    Thank you Mitchell
    Hows Lawton? Had a buddy that used to do the news there for a few years....
  • gimpod
    gimpod Posts: 1,793
    Valentine wrote: »
    Not to toot my own horn :o but as far as doing the crossovers check out this thread start at post #13 the bare board might be available in the near future.
  • Valentine
    Valentine Posts: 46
    Lawton is Lawton, not much coming or going. but its home atleast i have my SDA's
  • Vette C6.r
    Vette C6.r Posts: 1,560
    gim54pod wrote: »
    Def. look at Gim's handy work.
    Great stuff.
