Onkyo M504 amp questions?
Dabutcher
Dabutcher Posts: 2,604
edited September 2010 in 2 Channel Audio
What is the reason for the ground screw in the back of this amp? And if it is important,what do I ground it to? Second question is I love the sound from this unit . I think I want more power than the 165 watts per channel. One of my ideas is to buy a matching M504 and use one for each of my front towers bridged. Can these amps be bridged. As always, thanks for any help. Darryl
Post edited by Dabutcher on
  • halo71
    halo71 Posts: 4,631
    I have a M504 as well and am pretty sure its not bridgeable. I have never hooked up the ground on mine. Would assume you would connect a wire from the turntable to the amp though if you are getting a hum. I am running Monitor 10's off mine and would love to have another M504 to run them separate. Don't really need it, just want it! lol
    --Gary--
  • George Grand
    George Grand Posts: 12,258
    I don't think you can bridge those but if you get another you can bi-amp horizontally or vertically if those Polks will allow.
