need 2 complet system
luislane
luislane Posts: 6
edited September 2010 in Speakers
have apair or monitor 70 and hunting for a center ch, and a sub .have a large living room
Post edited by luislane on
  • sandworms
    sandworms Posts: 1,043
    hey luis, can you offer a little more info? Is this a question about what to buy, where to buy .....
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • luislane
    luislane Posts: 6
    what to buy.best maching m70
  • luislane
    luislane Posts: 6
    need center and sub.that will best match m70
  • flyfisher
    flyfisher Posts: 220
    A matching center would be a CS2 or CS20,Pretty much the same.As for the sub,if you are on a budget,One of the best bang for the buck subs is the PSW505.
    There are some others to look at like,SVS,HSU,Velodyne.Maybe other Polkies on here can give you more recommendations.
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
  • jinjuku
    jinjuku Posts: 1,523
    Budget, well performing sub, BIC H100, also Dayton CK1500 kit (minor assembly required).
