New to me SDA SRS 2.3TL's
  • headrott
    headrott Posts: 5,496
    edited September 2010
    This is not true. Klipsch acquired Aragon/Acurus in 2001. The 4004 MkII was designed and manufactured before that time. More info on Aragon amps here:
    http://reviews.ebay.com/Classic-Aragon-Amps-A-primer_W0QQugidZ10000000001149810
    You are correct. That is my mistake. I was thinking of the 8008 MkII. That is made by Klipsch. The 4004 AND 4004 MkII were both made by mondial. Thanks for the correction.
    Greg
  • Earthy
    Earthy Posts: 488
    So are we saying the Aragon 8008 MkII is a different design then the 8008bb?
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • headrott
    Earthy wrote: »
    The 8008bb is made by Mondial and the 8008 MkII is made by Klipsch. The design may be similar or the same, but the components are different defiantely.
    The 8008bb is the one to get, and skip the 8008 MkII.
    Greg
  • Jetmaker737
    Jetmaker737 Posts: 1,106
    headrott wrote: »
    Greg
    Hey now! :cool: I have the 8008 Mk II and it's my understanding (from the link I provided earlier) that it's identical to the 8008BB except that it has the Klipsch cosmetics (which I think look pretty cool)
  • headrott
    Not trying to bash your toy(s) at all.;) But, from what I understand, the 8008 MkII uses different components in it than the 8008bb. It's not just the cosmetics that are different. There are different tranformers, capacitors, resistors, etc. used in the Klipsch than the Mondial 8008.
    Greg
  • Jetmaker737
    Well... had to try and set the record straight on this so sent a note to Indy Audio Labs:
    My Note.
    Sent: Monday, September 20, 2010 10:45 PM
    To: support@indyaudiolabs.com
    Subject: Aragon 8008BB versus 8008 Mk II
    Hi,
    I have an Aragon 8008 MkII. Could you please tell me the differences (besides cosmetic) between the 8008BB and the Mk II? I've read that they are identical internally, but some people dispute that.
    Thanks!
    Response.
    Hello Rick,
    Sorry for the delayed response - we were all at the CEDIA show last week with limited access to email.
    Regarding differences, the most significant changes in the channel cards were around 1996 when the driver transistors were updated along with a few R's and C's. The newer units use the 2SA1837 and 2SC4793. The older units had the 2SA3298 and 2SA1306. Following that, the MK-II had no significant changes internally. Over the years there were a couple different transformer suppliers, however, the specifications were held pretty close among them from what we can tell.
    Let us know if you have additional questions.
    Thanks,
    Indy Audio Labs
