New Droid X
i have never used the task killer. whats it do?
metal Detector is fun. there is a heart rate one too. have you guys used the caller ID faker yet? you can call people and have the caller ID # on their cell appear as any # you want. you can change your voice as well.
Advanced Task Killer lets you individually stop any apps running on your phone. It saves battery--it's hard to tell what's running in the background without it.
Caller ID Faker sounds fun~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Pre installed stuff can not be uninstalled.
Also you might want to google app killers, they are not recommended and as of the 2.2 updated mine was **** up my phone after about 4 weeks of having it. Once I deleted it everything smoothed back out. The 2.2 upgrade looks to see if a app was improperly shutdown and restarts it so the app killer is not worth messing with anymore. Even when you go into the settings and change the kill type.
Just a recommendationHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Has anyone figured out how to synch Outlook calendar and contacts from Outlook with the Droid X? Apparently there isn't a native app to do so like there is with the BB...
I went to settings, selected accounts then new accounts and used corporate sync to set mine up with work. Calender, email and contacts all came across.
I am bummed about the email. No way to cut and paste that I can find. Coming from BB this is required.Speakers: SDA-1C (most all the goodies)
Still loving it, but it dropped ALL my Yahoo emails today....??TNRabbit
Sunfire TG-IV
I feel like a caveman with my ancient phone
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
