yamaha sub connections
scottyboy76
scottyboy76 Posts: 2,905
edited September 2010 in Speakers
MY sub has line in L&R and line out L&R, first does it matter if i hook up the sub cable is hooked to left or right in, also can i run another cable from line out to another subs line in {both are self powered} or should i spring for a splitter and run them separately.
By the way, my rec. does not have 2 sub output.
also, any good way to hook up two centers if your rec. does not have two center connections. thanx
humpty dumpty was pushed
Post edited by scottyboy76 on
  • kawizx9r
    kawizx9r Posts: 5,150
    You can daisy chain subwoofers by doing what you just asked; running one sub from the receiver and running the second sub using the line out on your first sub.
    Depending on the sub itself, if it does not have an LFE (in case it does, I'd recommend using that rather than the LINE IN L/R), most manufacturer's have you use the Left (white) input.
    If that's not the case, then I'd just use a y and split that sub out from the receiver out to both L/R input on your first sub.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • scottyboy76
    thanks freddy, but the last part, i dont get.
    is this right, splitter to BOTH L&R on first sub, then l go from L out from first sub to L in of second sub.
    If thats correct, why both L&R as opposed to just single cable to just L in of first, then cable form out L of first sub to L in of 2nd.
