What Speakers are the best combo?
setheman
setheman Posts: 5
edited September 2010 in Speakers
I am building a new home theater system and have narrowed my choices to the following. Any suggestions or opinions on what speakers configuration would be best is greatly appreciated.
Center = CS20 or CS2 Series II
Fronts = TSi200 or Monitor40 Series II
Rears = OWM3 or RC851
Sub= PSW125 or ???
Post edited by setheman on
    EndersShadow Posts: 17,747
    I would go with a CS2 for your center, your fronts are the same guts basically so go with whichever looks better/costs less. Your rears I would go with the OWM3's as they mount super easy w/ lots of options.
    For a sub I would look at the PSW505 or the DSW series from Polk at a minimum. Otherwise I recommend an SVS PB-12NSD. AVSFORUM's has a good list of subs based on price ranges here
  • setheman
    setheman Posts: 5
    Thanks. What do you or anyone else think about doing the OWM5's in the front and OWM3's in the rear. Thanks.
