Amplifier Concerns. What will work?
I bought : mtx 2 12" subs 200 rms with amp 250 rms (terminator package
Problem : Amplifier seems too weak. So i have looked to buy another. This other amp i plan on buying must be good for when i upgrade subwoofers.
2 Options:
1) mtx 1000xd watt mono amp with (1000 watt rms @ 2 ohms) (700Watt rms at 4 ohms)
2) kenwood 1800 watt max amp with cooling fans and stable to 1 ohm supossibly. (900 watt rms at 2 ohm) (500 watt rms at 4 ohm)
If i buy one of those, can i run either of them off my car battery efficiently if gain is only at 50% max>? (6 cylinder 2005 Mustang. Batt 1 year old). What if i put it to 100% (hypothetically).
Will these amps be pretty universal if i end up buying some 12" l7s (kicker) to them...or any other subwoofers?
Last...Will my 400watt (total) rms subwoofers be safe hooked up to this amp if i never turn the amplifier past (gain) 375 watts rms? Any large risks to this thinking?
THANKS A LOT FOR YOUR ANSWERS! i REALLY Appreciate it!
2 Options:
I don't know the answer to your question but just an FYI if you scroll down the page a little bit more when you click on forums there is a car audio section and the guys in there could help you greatly with your question.
Good luck!
Good luck!
Thanks, totally Missed it somehow.
