SDA's modded w/ active woofer
edited September 2010 in Vintage Speakers
http://minneapolis.craigslist.org/dak/ele/1920428376.html
turned passives into active drivers...what do you think?
Post edited by NeilGabriel on
Welcome!
    Part of me cringes when I read that. I wonder what the sonic cost was to pumping up an already great low end?
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
    so he can replace 12" passive radiators with active woofers but he can't take a picture of it and post it with his CL ad???
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
    wayne3burk wrote: »
    lol. probably for a good reason.
    Sad. Most likely didn't know how to set them up properly to get good bass with the passives.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
    fail
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
    Why is this an issue? Lots of people here do modifications that alter the original design (for example, swapping in new inductors that lower the DCR). While I will personally admit that adding an active driver in place of the passive seems like a pretty bad idea, perhaps this person loves the extra bass. Subjective preference is what matters, right?
    Moreover, at least this modification actually makes a real difference!
    I see you've been brainwashed by John's page too.
    I think it's a plain vanilla bad idea. If you install active woofers, I think you would need to port the cabinet. I also wonder how he integrated the new woofers into the 2-way crossover design.
    The world is full of answers, some are right and some are wrong. - Neil Young
    jcandy wrote: »
    Why is this an issue? Lots of people here do modifications that alter the original design (for example, swapping in new inductors that lower the DCR). Moreover, at least this modification actually makes a real difference!
    I think it is an issue because the PR is integral to the movement of the normal drivers. Having a big 12" active driver is going to create abnormal air pressure inside the cabinet that will interfere with the existing drivers, severely damaging the sound, if not the drivers. There is a reason that most cabinets with mixed speaker sizes are generally ported: cone travel of the smaller drivers may be exceeded by the large drivers displacement.
    On the bright side, he still has the passives, but he may have damaged the mids with his mod.
    I also think the sda bass is a little weak by modern standards, because the dynamic range of entertainment has grown since their introduction. If you want the full range of modern bass, get a sub.
    The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
    phocion wrote: »
    Funny!!! my SDA's have no problem with tight Bass.. WEAK??? Please..:rolleyes: there will never be a sub in my system.... No need for it..
    dcmeigs wrote: »
    Yep that would be the most important thing. I suspect not a lot of design effort was put into it,but hopefully he isn't just running the new woofer unfiltered and in parallel with the mid bass's up to the 2k- ish crossover point.:eek::eek:
    phocion wrote: »
    Of course, what you're saying is completely correct. My point was that people do all sort of modifications which may or may not improve things, with the only criteria being that its subjectively better. I agree that its highly doubtful that adding an active driver is a good idea, but who am I to say :)
    phocion wrote: »
    I recently measured some SDA2Bs, and the bass response actually has a +4dB peak at 65Hz, which can lead to an impressive and/or boomy sound depending on the room. But I think your point is that the rapid roll-off below the passive tuning frequency (the SDA2B is down -10dB at about 32Hz) means they don't really capture the lowest octave most HT buffs are used to.
    One of the problems with very deep bass (below 30Hz) is that traditional floorstanders have started their -12db/-24db per octave roll-off by then. Although room gain can help in the 20Hz range, the presence of room modes and suckout will leave the in-room response looking pretty bad. So, I think the only way to have clean bass response in the < 30Hz range is to have multiple subs with an active filter (like the FBQ2496, for example).
    Nose candy?
    Ben
    Hey Ben!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    ben62670 wrote: »
    nose candy?
    :D:D
    Greg
    Well, you have demonstrated an excellent technical capacity to improve the frequency response of SDA's :) It is unfortunate that more people have not been exposed to that mod. I am looking forward to upgrading my 1C's with rings some day soon, so I too can eschew the sub during music listening! For HT, I still expect to use a sub, because the separate channels necessitate it.
    My SDA's don't see HT duty..
    jcandy wrote: »
    Agreed but response into the 30's should suffice for music unless your a pipe organ fan.
    jcandy wrote: »
    Can we flush this **** yet?
    FTGV wrote: »
    Or post 90s Kraftwerk, or Juno Reactor, etc.
    1. Keyboard Warrior
    1. A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
    jcandy wrote: »
    1. Keyboard Warrior
    Many of us have met him, you couldn't be more wrong.
    So He's not allowed to have an opinion?:confused:
    Face wrote: »
    Yeah, he's an **** in real life, too :p
    Active woofer in a spot meant for a passive is a bad idea, unless you port the cabinet (and tune the port). Plus, as others have said, the crossovers are not designed for this.
    The SDA's were designed to be MUSICAL speakers, NOT HT speakers. They're not intended to crumble your foundation with LFE explosions. In an HT environment, yes, they probably should have reinforcement from a sub. In music... not necessary.
    Ludicrous gibs!
    nadams wrote: »
    As soon as I get out of school and get my own house, a 2 channel room is certainly in the cards. I am jealous of you guys that have the space to let these monsters really sing! Some of the pics of setups on here are completely drool-worthy. *sigh* Until then, double duty for the SDA's...
    FTGV wrote: »
    Since when did trolling become justified as having an opinion?
    Trolling?I guess our definitions of that term are vastly different.Unless I've missed something I don't see anything I would consider trolling.
    Come on Fred, his question as to why this is an issue should have been your first clue.
    ...his question as to why this is an issue...
    While I think most of us disagree with his statement but if thats considered trolling then we are all guilty of similar comments.While I'm obviously in the minority I did find the info in his SDA measurement thread interesting and informative but he took a few unwarranted shots in jibbies from some.At the risk of sounding like his defense attorney it does'nt sit well with me that a new member and IMO knowledgable one gets pissed on for offering up some performance data.
Welcome!
Welcome!
