Doing the "MOD"
bsturgeon89
bsturgeon89 Posts: 128
edited October 2010 in DIY, Mods & Tweaks
As many have put it on here....I will be on my way to the "audio nirvana" state of mind next week!!
The rings, caps, and resistors will be arriving next week for the 2.3TLs. The 198s are gonna have to wait for a few more weeks. Also have the dynamat extreme ready to go.
I understand there will be a burn in time but I'm stoked. I really anxious to hear the drastic difference of the before and after and hopefully my ears aren't too far gone to distinguish the difference.
This should fun.:D
Post edited by bsturgeon89 on
  • TrashyTrucker
    TrashyTrucker Posts: 225
    edited September 2010
    bsturgeon89,
    Im with you! Can't wait for my packages to arrive as well. I will be joing you in "the mod". As far as the burn in, I plan to take it easy and let them move in gradually. It will be real fun I totally agree with you. :D
    Matt
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • george daniel
    george daniel Posts: 12,096
    We are doing the rings too? Wow-- you ain't messin' around are you? See you there --Zoot Horn
  • Bubinga99
    Bubinga99 Posts: 283
    Hi Brock, I'll attach some drawings I made which may make the mods a little easier for you, in terms of keeping track of what goes where.
    I already removed the polyswitches and replaced them with 1/2 ohm 12W resistors before I sold the speakers to you (so you'll have a couple spares I guess). I also checked out all the wiring, which can be fairly time consuming so you don't need to do that. The second document shows all the measured values for your speakers (by serial number) and I also checked the ESR on all the caps (not shown in the doc) and all were OK.
  • bsturgeon89
    Hey Matt,
    Good luck with your project. We'll have to compare notes afterwards.
    Thanks Dave for the all the info and heads up. That will make things alittle easier to follow. I have a couple forum buddies helping me out.
    I'll let ya know how it turns out.
  • bsoko2
    bsoko2 Posts: 1,449
    You're going to love it when the mod is finished. I ran my 2.3TL's 18 hrs a day for two weeks for burn in. You will notice a difference as soon as you turn them on.
    Bill
  • Bubinga99
    On the one hand I'd hate to set his expectations too high, but on the other hand it's pretty rare that people don't hear an improvement when they do a crossover upgrade.
    The 3 main things that can change (hopefully for the better) the sound when you do a crossover upgrade:
    1) the switch from NP electrolytic caps to film caps
    2) the change in measured/actual values from old caps to new, and/or the difference between the left and right speaker measured values.
    3) replacing caps that were beginning to become defective (e.g. high ESR) with fully functional new caps, even if the replacements were of the same type and were exactly the same measured values.
    #3 doesn't apply in this case because I measured all the values and ESR's before I sold the speakers and they were all OK.
    #2 could be more significant than #1 (though #1 would still have an effect) if there's a large difference between the actual values of old and new. That's whay I provided the actual measured values. So for example the measured value of C4 in the left speaker is 17% higher than the nominal schematic value. Since Brock probably ordered values as close as possible to the schematic values, he could very possibly hear a change even if he only replaced C4. I assume Brock probably got 1% tolerance caps, so he can probably trust the value stamped on the case even if he has no way to measure it.
    Other possible things (not counting cabinet mods) that could have an effect on sound when doing a crossover upgrade:
    --Polyswitches going bad and being replaced by a fixed resistor (already done so doesn't apply in Brock's case, but this alone could have an effect that can be heard).
    --Old resistors measure out of tolerance or have high inductance
    --Connector contacts oxidized, or loose
    --Flakey wiring or wrong internal wiring (e.g. plus and minus swapped)
    Probably some others I'm not thinking of at the moment...
    If you want biggest bang for the buck, hold off until you can do the tweeters at the same time. I guess it all depends how many stages of tinkering and burn in you want to go through (not to mention financial considerations regardless of that), and some people enjoy the tinkering part more than others.
  • bsturgeon89
    I've been busy but I just wanted to give a shout out to George and Jerry for their help modding the crossovers. When I can find the charger to the camera, I will post their beautiful craftmanship.
    I do believe I'm in the "growing pains" phase!! Only about a week to go.
  • bsturgeon89
    edited October 2010
    Here is the work of George and Jerry and their handywork on the crossovers. George did the first one and Jerry helped on the 2nd one.
    Just want to say thanks again to both of those guys for helping a fellow out.
    The speakers are sounding very good:D
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    They are great guys. I miss and love them :)
    Ben
