sansui au-717
thebluemonkey
Selling my excellent sounding au-717 sounds great just have too much power supply rebuilt two monthes ago so all ready to go.$200
Post edited by thebluemonkey on
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
I'm impressed snow, the insides look great, is that bad boy running discrete channels???
Yes.Polkie2009 wrote: »I'm impressed snow, the insides look great, is that bad boy running discrete channels???
The Sansui AU-717 was first sold in 1977 for a MSRP (Manufactuer's Suggested Retail Price) of $550.00. That's $1979.00 in 2010 dollars. It is a dual mono block design, which means there are two power transformers with associated circuits and components. This is an expensive design that allows each channel to function virtually independent from the other, allowing for improved sonic performance.
The AU-717 continues to be a very sought after integrated amplifier to this day, with new enthusiasts discovering the benefits of it's over-design all the time.
Specifications:
Power Output: 85 watts RMS per channel into 8 ohms.
Power Bandwidth: 20 to 20,000 Hz at or below rated min. RMS power output and total harmonic distortion.
Total Harmonistic Distortion: less than 0.025% at or below rated min. RMS power output.
Intermodulation Distortion (70Hz : 7kHz = 4:1 SMPTE method): less than 0.025%.
Damping Factor: approximately 60 at 8 ohms.
Controls:
Speakers: Off, A, B, A+B
Bass: +/- 10
Treble: +/- 10
Balance
Volume: Log dB Scale
Switches:
Powerc
Treble: 6kHz/3kHz
Bass: 400Hz/200Hz
Tone: Defeat/On
Subsonic Filter: On/Off
High Filter: On/Off
Loudness: On/Off
Muting: Off/-20dB
Tape Monitor: Source, Tape 1, Tape 2
Tape Copy: Tuner, Off, Source, 1>2, 2>1
Input Selector: Aux, Tuner, Phono 1, Phono 2
Jacks:
Headphones
Indicators:
Power/Protect LED
AUX
TUNER
PHONO 1
PHONO 2
Rear Panel:
Pre-Out/Main-In (L, R)
Phono 1 (L, R)
Phono 2 (L, R)
Tuner (L, R)
Aux (L, R)
Tape 1 Record (L, R)
Tape 1 Play (L, R)
Tape 2 Record (L, R)
Tape 2 Play (L, R)
Pre-Power Amp: Connected, Separated - Direct Coupled, Separated - Capacitor Coupled.com
AC Outlet Unswitched (2)
AC Outlet Switched (1)
Speaker System A (L, R)
Speaker System B (L, R)
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Old Sansui rocks. Am I correct to assume that this is NOT a common ground design?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
OP where are you located?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
auburn
Very nice amp and more powerfull than the ratings indicate. I'm a big fan of vintage Sansui,amps ,receivers,Marantz too. They sure don't make 'em like that anymore. Good luck with the sale.HT SYSTEM-
lsi 9's -
Shipping quote to 46237?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
auburn is 2 hours north of indy
thebluemonkey wrote: »auburn is 2 hours north of indy
Oh. THAT auburn. Was thinking Texas. My bad.
Alrighty, let me see what i can do.
Will let you know, but don't hold it. Gotta work out semantics on getting it to St. Louis. I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
i am , interested if it is still available
excuse the extra post , i would like to know what to use to lubricate the controls with and clean dust from the inside , i have one of these amps already and would like to run two of them. imgebo@yahoo.com
I am also interested. Is it also for 230V so can it be used in Europe? There is fuse cup for 110V and 230V but does it mean anything.
sansui is sold
