sansui au-717
thebluemonkey
thebluemonkey Posts: 190
edited September 2010 in For Sale (FS) Classifieds
Selling my excellent sounding au-717 sounds great just have too much power supply rebuilt two monthes ago so all ready to go.$200
Post edited by thebluemonkey on
  • snow
    snow Posts: 4,358
    Nice amp for a very good price, heres a pic of what the insides looks like.
    REGRDS SNOW
  • Polkie2009
    Polkie2009 Posts: 3,834
    I'm impressed snow, the insides look great, is that bad boy running discrete channels???
  • snow
    snow Posts: 4,358
    Polkie2009 wrote: »
    Yes.
    The Sansui AU-717 was first sold in 1977 for a MSRP (Manufactuer's Suggested Retail Price) of $550.00. That's $1979.00 in 2010 dollars. It is a dual mono block design, which means there are two power transformers with associated circuits and components. This is an expensive design that allows each channel to function virtually independent from the other, allowing for improved sonic performance.
    The AU-717 continues to be a very sought after integrated amplifier to this day, with new enthusiasts discovering the benefits of it's over-design all the time.
    Specifications:
    Power Output: 85 watts RMS per channel into 8 ohms.
    Power Bandwidth: 20 to 20,000 Hz at or below rated min. RMS power output and total harmonic distortion.
    Total Harmonistic Distortion: less than 0.025% at or below rated min. RMS power output.
    Intermodulation Distortion (70Hz : 7kHz = 4:1 SMPTE method): less than 0.025%.
    Damping Factor: approximately 60 at 8 ohms.
    Controls:
    Speakers: Off, A, B, A+B
    Bass: +/- 10
    Treble: +/- 10
    Balance
    Volume: Log dB Scale
    Switches:
    Powerc
    Treble: 6kHz/3kHz
    Bass: 400Hz/200Hz
    Tone: Defeat/On
    Subsonic Filter: On/Off
    High Filter: On/Off
    Loudness: On/Off
    Muting: Off/-20dB
    Tape Monitor: Source, Tape 1, Tape 2
    Tape Copy: Tuner, Off, Source, 1>2, 2>1
    Input Selector: Aux, Tuner, Phono 1, Phono 2
    Jacks:
    Headphones
    Indicators:
    Power/Protect LED
    AUX
    TUNER
    PHONO 1
    PHONO 2
    Rear Panel:
    Pre-Out/Main-In (L, R)
    Phono 1 (L, R)
    Phono 2 (L, R)
    Tuner (L, R)
    Aux (L, R)
    Tape 1 Record (L, R)
    Tape 1 Play (L, R)
    Tape 2 Record (L, R)
    Tape 2 Play (L, R)
    Pre-Power Amp: Connected, Separated - Direct Coupled, Separated - Capacitor Coupled.com
    AC Outlet Unswitched (2)
    AC Outlet Switched (1)
    Speaker System A (L, R)
    Speaker System B (L, R)
    REGARDS SNOW
    nooshinjohn Posts: 25,925
    Old Sansui rocks. Am I correct to assume that this is NOT a common ground design?
  • schwarcw
    schwarcw Posts: 7,358
    That is a very nice amp!!
    Carl
  • concealer404
    concealer404 Posts: 7,440
    OP where are you located?
  • thebluemonkey
    tonyb Posts: 33,072
    Very nice amp and more powerfull than the ratings indicate. I'm a big fan of vintage Sansui,amps ,receivers,Marantz too. They sure don't make 'em like that anymore. Good luck with the sale.
  • concealer404
    Shipping quote to 46237?
  • thebluemonkey
    auburn is 2 hours north of indy
  • concealer404
    Oh. THAT auburn. Was thinking Texas. My bad.
    Alrighty, let me see what i can do. :) Will let you know, but don't hold it. Gotta work out semantics on getting it to St. Louis.
  • imgebo
    imgebo Posts: 2
    i am , interested if it is still available
  • imgebo
    imgebo Posts: 2
    excuse the extra post , i would like to know what to use to lubricate the controls with and clean dust from the inside , i have one of these amps already and would like to run two of them. imgebo@yahoo.com
  • jarpes
    jarpes Posts: 1
    I am also interested. Is it also for 230V so can it be used in Europe? There is fuse cup for 110V and 230V but does it mean anything.
  • thebluemonkey
    sansui is sold
