Elan Z-660 amplifier
B Run
B Run Posts: 1,888
edited September 2010 in Electronics
So i'm doing my daily craigslist browsing and I came across an Elan z-660 6-channel home theater amp, which can be be bridged to 120watts rms @ 8ohms. Originally I was considering purchasing this to run my fronts but what little info I could find says the sound quality sucks and it wouldn't be an improvement from my Rxv-1800. However after e-mailing the guy I got him down to $75 and it's still in the original box and plastic wrap. The "retail" price is $820 and I found a few used in the 250-300 range. So should I just scoop this and ask questions later, try to use it, or buy it and try to throw it on fleabay? Any advice or opinions on these amps would be appreciated. Thanks.
Post edited by B Run on
    heiney9 Posts: 25,497
    Honestly, after doing a Google search the descriptions and pics look cheesey as in really cheap junk made with advertizing copy and pics to make it seem like it's cutting edge stereo gear.
    I'd stay far away as they have the look and promotion of "white van" products.
    YMMV
  • B Run
    B Run Posts: 1,888
    I was getting that vibe too, I saw people were using them for small outdoor speakers and things like that, thanks for the advice. I just wanted to make sure I wasn't passing on a decent or underpriced amp for $75.
  • jrgoswick
    jrgoswick Posts: 159
    Elan isn't crappy gear(not cutting edge either). It's just now what you're needing. When I used to do whole home installs, that's what I used(been years ago). If you're wanting to power a couple of zones for background, snag it. Otherwise, I'd leave it alone-it won't be an improvement over what you've got.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • B Run
    B Run Posts: 1,888
    Yeah the reason I was looking was for home theater purposes and want a 3 or 5 channel amp that would be a step up from my Yamaha. Doesn't sound like what I need but I knew this was the place to come ask. Thanks for the help.
  • Serendipity
    Serendipity Posts: 6,975
    heiney9 wrote: »
    YMMV
    Are you kidding? Elan is sold in high-end audio stores specifically for the custom install market. Far from junk, and very expensive.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
