Polk outdoor speakers indoors?
mma518
mma518 Posts: 4
edited September 2010 in Speakers
Due to space and ceiling limitation, I want to install 4 speakers and a subwoofer in a 24 by 15 party room just for music/dancing. I will drive these speakers with a 4 channel amp and compliment with a powerful sub. The ceiling is 7 ft high. No surround or movies setup is needed.
Anyone has experience installing Polk outdoor speakers indoors? I love the flexibility of installing the outdoor speakers on the wall (and their unimposing shape), but concerned if they can work for loud dance music or if they work decently at all indoors.
Thank you in advance for any advice.
Post edited by mma518 on
  • classic carl
    classic carl Posts: 663
    7 foot ceilings? Are you serious?
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Teac R-919X
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • mma518
    mma518 Posts: 4
    yup, serious. a dancing room with a bar in the basement. It is a little over 7 ft ceiling.
    Thanks!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Outdoor speakers could work they can get loud, what are you driving them with?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • mma518
    mma518 Posts: 4
    Thanks Disneyjoe7! Have not decided yet and looking for a recommendation on a 4 channel amp as well. this is a completely new setup and will be starting from scratch. I do have a 7.1 system in the main room, but would like to keep the two separate.
    Thanks again!
  • jimmydep
    jimmydep Posts: 1,305
    I think the Atrium series would work fine for this, and they'll hold up well when your New Years party gets wild and your guests start spraying champagne all over the place.
  • Polkersince85
    Polkersince85 Posts: 2,883
    Mount some Monitor 10s on the wall and call it a day,
  • mma518
    mma518 Posts: 4
    Thanks! have two options now and will look into the Monitor 10s. Good idea!
