SDA 1#'s or RTi10's
Anyone have experience with both of these speakers?
Which one would you go with if both were in excellent shape and the price was right?
Thanks.
Thanks.
Post edited by joko38 on
Depends on what you already have and on what you plan on using them for. I had a pair of RTi10's and they were fantastic speakers, but if I had the choice, I would get the SDA's, hands down. What do you plan on powering them with?Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
I plan to power them with a 200w NAD amplifier.
That should be plenty of power. Will they be for music or home theater? If music, then hands down, go for the SDA's. If HT, the RTi10's may have a slight edge, but lots of people here use SDA's for HT with great results. Try the SDA's first, IMO, you won't be dissapointed.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Keep in mind that the SDAs like to have 15 feet or more of wall space to fully develop the SDA effect.5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Ah, but when you do...
I'm running my 1B's non-ideally about 4 feet between and 4 feet from each side wall. Not as pronounced as my old setup but the SDA effect is still very apparent and it rocks the movies as well!Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
