RM6700 and Mirage LF-100 mixing
klhening
I just bought the RM6700 package and a Mirage LF-100 subwoofer. The subwoofers crossover stops at 120. Am I missing a lot of sound with this setup? Should I take the subwoofer back and get something with a higher cutoff on the sub? I have a small room and do not need big booming sound.
Post edited by klhening on
The main thing is how it sounds to you. If you are happy with the sound that's all that matters.
Having said that, yes technically you have a gap in your frequency response from 120Hz. - 150Hz. As you may already know (since you posted this thread) the 6700's have a internal crossover filter set to 150Hz. Everything below that needs to be routed through the sub.
You will need a sub with a crossover setting of 150Hz. to eliminate the gap.
Good luck and have fun. I love my little 6700's.
Denon AVR-1803
Polk RM6700 w/ Infinity Entra Sub
