RM6700 and Mirage LF-100 mixing
klhening
klhening Posts: 1
I just bought the RM6700 package and a Mirage LF-100 subwoofer. The subwoofers crossover stops at 120. Am I missing a lot of sound with this setup? Should I take the subwoofer back and get something with a higher cutoff on the sub? I have a small room and do not need big booming sound.
Post edited by klhening on
  • section19
    section19 Posts: 90
    edited December 2003
    The main thing is how it sounds to you. If you are happy with the sound that's all that matters.
    Having said that, yes technically you have a gap in your frequency response from 120Hz. - 150Hz. As you may already know (since you posted this thread) the 6700's have a internal crossover filter set to 150Hz. Everything below that needs to be routed through the sub.
    You will need a sub with a crossover setting of 150Hz. to eliminate the gap.
    Good luck and have fun. I love my little 6700's. :D
    Denon AVR-1803
    Polk RM6700 w/ Infinity Entra Sub
