Looking at Dual turntables. Comments?
helipilotdoug
helipilotdoug Posts: 1,230
edited September 2010 in Electronics
I've been looking at Dual turntables, and have heard some pretty good things about several models. I remember them from back in the day too, and they were highly regarded back then. Here is a Dual CS 714Q I'm seriously considering.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0473817374
Another model that I'm considering, and can get fully rebuilt with a new cover and base, is a Dual 1229 for $425. This from a guy who rebuilds Duals at http://www.fixmydual.com/
Any comments appreciated.
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
Post edited by helipilotdoug on
  • HB27
    HB27 Posts: 1,518
    I've had dealings with Bill at "fix my Dual" and he's a straight up guy.
    Throwing in my opinion here...
    For that money you can land yourself a much quieter table with better sound. The old Dual tables are a good "old" table but have a tendency to be noisy. They're also a very complicated table using a lot of moving parts. "old, many parts" complicated" = a potential for lots of maintenance and downtime. JMO.
    I've got 1229, 1219, and a 1228 here right now. ALL of them need taken apart and gone through. The sound quality of these tables is better than average but....
  • TNRabbit
    TNRabbit Posts: 2,168
    Thorens would probably be a better "vintage" TT....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • helipilotdoug
    HB27 wrote: »
    Any suggestions for that much quieter table with better sound? Thanks :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • hearingimpared
    hearingimpared Posts: 21,136
    You can get new Dual turntables from Quest for Sound.
    PM on the way.
  • JPSmario
    JPSmario Posts: 142
    my 1229 runs well after a local guy overhauled it a couple of years ago. he had to do something to 'soften' the rubber drive disc (this design is most of the reason people consider them noisy) because he said he couldn't buy them anymore. does anybody know if this has changed?
    I bought it new in 73' and it's been good to me. I think it's better than a lot of the 80's direct drive tables, but many belt drive TT's have usually been considered superior.
    Jim
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
  • HB27
    HB27 Posts: 1,518
    I'm pretty sure EG Russell still makes a good replacement idler wheel for them. I bought a couple this spring from a local electronics store and I still see them stocked on the wall display.
    JPSmario wrote: »
    Jim
