Tile Ceiling and Imaging
Cpyder
Cpyder Posts: 514
edited September 2010 in 2 Channel Audio
I've got a new listening room with sound dampening panels in it but I'm not happy with the soundstage imaging. And I'm quite sure it has to do with the ceiling's thin foam-like panels. What would you guys recommend doing to remedy this? Right now, I'm thinking that putting carpet squares on the ceiling would be the cheapest and easiest but does anyone have any other suggestions? Thanks!
Post edited by Cpyder on
  • organ
    organ Posts: 4,969
    edited August 2010
    You said it's cheap and easy, so why not try it? If you go for the more $$ route and it doesn't work out, you'll probably wonder if your original idea would have worked, which you'll probably end up trying;).
    This is just IMHO, but I don't think it's your ceiling. You said it's thin foam like panels. This should do quite a bit of absorbtion. What's behind the panels?
    A lot of times treating the front wall can really help with soundstaging. This would absorb the sound that just finished bouncing off the back wall and going to hit the front wall again, where they're absorbed. You can place layers of thick blankets on the wall between the speakers and see what happens. Just a thought. My soundstage always improves when I put thick blankets over my 46" lcd.
  • Flash21
    Flash21 Posts: 316
    edited August 2010
    If you color the edges of the panels green with a magic marker, they'll sound a lot better. ;)
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • quadzilla
    quadzilla Posts: 1,543
    edited August 2010
    First, the tiles are probably acting as a bass vent. They may also be making the ceiling too dead at higher frequencies. I'd be more inclined to yank the dropped ceiling entirely.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • bld
    bld Posts: 25
    If you feel you have to put treatment to your cieling,If it were me i would cut a piece of 1/2" plywood then cut the middle out leaving about a 4" frame with a square hole in the middle,then staple some insulation to the backside and cover the front or bottom side with a fabric of your choice of color.
    nad t175 processor
    Sunfire TGA 7401 amp
    LSi15 front
    LSi center
    LSI 9 surround
    dual sunfire hrs 12 subs
    LG bd 390 blueray
    Sonos
  • amulford
    amulford Posts: 5,020
    How do you have your treatment positioned?
  • Cpyder
    Cpyder Posts: 514
    amulford wrote: »
    I have 6 wall panels that are made out of the thickest fiberglass insulation I could find and lose canvas. Now I have four 3'x4' carpet squares on the ceiling. The ceiling was definitely acting as a bass trap. It's better but not amazing. I don't really have the option of tearing down the ceiling.
  • dorokusai
    dorokusai Posts: 25,623
    I recommend an equally cheap alternative, just alternate your tiles with non-acoustic tiles. You don't have to create a perfect room, or an acoustically inert ala anechoic chamber room....keep some life in it.
    Don't overthink it yet, play with the room a little and keep it simple.
  • amulford
    I would replace the canvas with a more accoustically transparent material. They are probably working on the bass but the higher frequencies are probably just reflecting off the canvas and contributing to smearing your imaging.
    As for placement, there are guides available, but I would shoot for the first reflection points on the side walls, in between the speakers up front, and directly behind your sweet spot.
