How to tin bare wire
acmf74
acmf74 Posts: 937
edited September 2010 in Basic Hookup/Wiring Questions
I was to try to tin the some speaker wire. Do I need special solder or just use the plain electrical kind?
Post edited by acmf74 on
  • fishbones
    fishbones Posts: 947
    edited August 2010
    Guys who do it often (soldering) usually recommend a silver content in the wire for a purer signal. I have used one that was recommended on here from Rat Shack. It was reasonably priced and worked well (I think it had a 2% content). Was there a sound improvement over regular solder? I'll never know.
    IMM, if there is a possibility of a difference of one being better than another, and it's within reason, I'll usually go with what the experienced recommend to make sure I do it right the first time, just in case.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2010
    You may use regular solder if you like, it's just fine. I use a high quality solder because I believe there is worth in doing so. The Radio Shack recommendation or Parts Express product would also be a viable option.
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2010
    Put the soldering iron under the wire. Touch the solder to the top of the wire. Let it flow into the strands. Quickly wet your thumb and fore finger, and pull the tinned wire between them to remove excess solder.
  • Fongolio
    Fongolio Posts: 3,516
    edited August 2010
    I use liquid rosin and silver solder for tinning using technique above.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2010
    Fongolio wrote: »
    you can buy 60/40 solder which doesn't need any external rosin as it is in the core of the solder. You have to be carefull of what you use, some stuff is no longer recommendable as breathing it is toxic.
    As pointed out, you heat the bare wire, not the solder. With a clean tip and sufficient heat, while you apply the solder over the bare wire, the solder should melt and flow through the strand like butter in a pan.
    You have to make sure the tinning doesn't get to close and/or inside the insulation as it creates a weak point which will eventually break.
    Enjoy :)
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • ShinAce
    ShinAce Posts: 1,194
    edited August 2010
    60/40 refers to the mix. It only means the solder is 60% tin and 40% lead.
    The rosin built in to the solder is called, 'rosin core'. I use rosin core myself as most soldering is small stuff. Larger parts and hard to heat parts could benefit from seperately applying rosin, or flux paste.
    It's best to clean the cooled solder with a toothbrush and some alcohol if using rosin core. The rosin will eat away at stuff if it sits there a long time, like a tinned speaker wire.
    I say use rosin core, or plain old electronics solder.
  • TECHNOKID
    edited August 2010
    ShinAce wrote: »
    Make sure not to reuse the toothbrush the next morning as you may find it somewhat sticky, will not clean your theeth either as it will rather make sure the debris actually bonds real well to your theeth :D
    Yep, alcool or isopropanol is a great way to clean the xcess flux afterward.
    DARE TO SOAR:
  • Fongolio
    edited August 2010
    But my breath smell so sweet after brushing with a rosin soaked brush!!
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • TECHNOKID
    edited August 2010
    Fongolio wrote: »
    I would believe there is nothing to smell as the lips would sealed :eek:
    DARE TO SOAR:
  • faster100
    faster100 Posts: 6,124
    MY opinion, get the flux paste.. a little go's a long way and you don't chance melting the outter wire covering with to much heat.specially if your new to soldering, I use silver solder nothing special, the real fine/thin stuff. have a wet sponge/rag to clean the tip as needed, also helps
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • george daniel
    george daniel Posts: 12,096
    Cliff,,is that you?
    F1nut Posts: 51,917
    Writes and spells like Cliff.
  • Face
    Face Posts: 14,340
  • jinjuku
    jinjuku Posts: 1,523
    Another trick is to put a small bead of solder on the tip of the iron, when the speaker cable wicks it up you are good to apply solder directly to the copper strand.
  • faster100
    Cliff,,is that you?
    Yes it is. :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
