Best 7 Ch Amplifier for Lsi Speakers under $2000
veerapaneni
Hi I have following setup and need a good 7 Channel Amplifier for my setup which is under $2000. I have searched the forum but could not come up with an answer
Front: Lsi15
Center: LsiC
Side Surround : LsiFX
Back Surround (Need to buy . either LsiFX or Lsi9)
Reciever: Denon 3311
Amplifier: Emotiva Xpa-5
Front: Lsi15
Center: LsiC
Post edited by veerapaneni on
You can't find the answer because there is NO one answer to this question.
You have to make the decision for yourself how much you want to spend on the amp. You obviously know that you need a lot of power to get the best out of your LSI's which is why you have the Emotiva (I'm assuming).
You can either add a 2 channel amp to the mix or get a 7 channel amp. There are lots of choices for amps, but no one can tell you which one is the best one of the lot.
Do your research and choose one.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
A little above your budget, but an excellent amp: http://www.wyred4sound.com/webapps/site/74030/117839/shopping/shopping-view.html?pid=339145&b_id=&find_groupid=18048"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
If you currently like your emotiva why not just let it power your other 5 speakers and get something really beefy for your 15s? That's what I plan to do if I ever go back to a 7 channel setup... but I gotta get back to a 5 channel before I think about that
I purchased a used B&K 7270 SII for 7 channels of LSi. You can get the updated 200.7 for around $1400.
Sunfire rocks.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Sunfire rocks.
+1. Here's a 2 chan amp, 600 watts @ 4ohms is plenty and the price is excellent.
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1287791493&/Sunfire-300-Two-Channel-Power-Shoot the jumper.....................BALLIN.............!!!!!
how would my system sound if i use sunfire for my fronts and Emotiva XPA-5 for Center and surrounds. would they work fine together ? -
anonymouse wrote: »+1 I would do this as well. Stick with that Emotiva and get something like a Rotel RB1090. Those LSi15's will be in heaven.
I could do that. The only reason i am thinking otherwise is because of space issues. Otherwise i love my emotiva ( I did not hear any other amplifier except this one:D ) -
How does this look ? Rotel RB-1092 for $1350 ?
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1287813211&/Rotel-RB-1092-500w-x-2-Stereo- -
Sunfire would sound great with the LSi's. Quite a few of us have them in our setups. I own a TGA-5200 multichannel amp and love it. I run my fronts on an IceAmp @525 wpc. The Sunfire will power anything you throw at plus you save some coin, email the seller I'm sure he/she may work a better price. Worth the look for sure, that amp is in very good condition.Shoot the jumper.....................BALLIN.............!!!!!
Does anyone know the dimensions and weight of Sunfire 300 ?
grimmace19 wrote: »If you currently like your emotiva why not just let it power your other 5 speakers and get something really beefy for your 15s? That's what I plan to do if I ever go back to a 7 channel setup... but I gotta get back to a 5 channel before I think about that
This is sage advice. I have big power on my Lci HT most of just sits wasting away. -
veerapaneni wrote: »Does anyone know the dimensions and weight of Sunfire 300 ?
Per the website
17" w X 5.9" h X 16.7" d
Weight is 36lbs
In my case I had to have mine shipped to Japan so weight was definitely a factor for me.
PDF in case your interested.
http://www.sunfire.com/manuals/Sunfire%20Series%20II%20Architects%20Choice%20Stereo%20Power%20Amplifier%20Manual.pdfShoot the jumper.....................BALLIN.............!!!!!
+1 Sunfire
http://www.polkaudio.com/forums/showthread.php?t=101645
http://www.polkaudio.com/forums/showthread.php?t=89779
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's and SUNFIRE Cinema Grand
03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
06) HITACHI P55T501. 55" HD1080 Plasma HDTV
07) POLKAUDIO LSiC (Center speaker)
08) POLKAUDIO LSi15 LEFT (Front speaker)
09) POLKAUDIO LSi15 RIGHT (Front speaker)
10) POLKAUDIO LSiC Vertically (Surround speaker)
11) POLKAUDIO LSiC Vertically (Surround speaker)
12) POLKAUDIO LSif/x LEFT (Surround back speakers)
13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated) -
honestly I would just buy a stereo amp for the front L/R and go that route. If you already have a 5 channel it would be the best. Otherwise get a small stereo like the UPA-2 for the rears and keep the XPA on the front and sides. There is not a whole lotta info going in there and a UPA-2 would be just fine there. Its a low cost solution as well if you didn't want to spend a lot of coin.
If you really really want a 7 channel B&K, Adcom, and ATI are pretty goo routes to go for a smaller budget. -
I have the following 2 in mind . Confused which one to pick . I am planning to keep my XPA-5 .
Sunfire 300 watts x 2 $777. includes shipping
Sunfire Cinema Grand 17 series 225x5! for $1075 + Shipping -
veerapaneni wrote: »I have the following 2 in mind . Confused which one to pick . I am planning to keep my XPA-5 .
This one since you are keeping the Emo.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Any comments on how it would sound if i use sunfire 300 for fronts and emotiva for center and surrounds? I have lsi 15 as fronts and lsic as center and lsifx as surrounds.
It should sound fine. Just recalibrate all your speakers & you should be all set.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
+1 I would try to run the front 3 off the same amp, thus keeping the Sonic qualities of the L/C/R the same. -
Honestly if you added the sunfire to the front and kept the emo powering the surrounds ect you probably won't notice much of a different for HT. If you would be say listening to a lot of SACD ect you would possibly notice a difference but for normal HT you would be fine. You may also notice a difference for 2 channel listening.
Honestly though if you wanna keep it all in the Emo family do the UPA-2 for the rears. They really don't need all that much power in a 7.1 system as they are not going to be seeing that much information and it would be a low cost so that you could spend that money on something else...like more movies..lol -
The Sunfire will provide a more natural sound to the mains when listening to music...
There is a Sunfire Signature 7/400 on Audiogon right now and on Craigslist as well.
www.craiglook.com
type sunfire signature in the search.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
+1
Amp manufacturers don't share the same gain rate.
Emotiva gain is set unusually high, from what I understand.(32dB)
Not saying it will be a problem with 2 different brands, but possible.
Something to watch out for. -
found Sunfire Cinema Grand Signature 400-7 for $1850 + shipping. Is this a good deal?
veerapaneni wrote: »found Sunfire Cinema Grand Signature 400-7 for $1850 + shipping. Is this a good deal?
ok. I got Sunfire Cinema Grand Signature 400-7 for my Lsi Series speakers. It will be delivered in few days and i eager to test it. -
I agree. Hard to beat in the right system -
veerapaneni wrote: »ok. I got Sunfire Cinema Grand Signature 400-7 for my Lsi Series speakers. It will be delivered in few days and i eager to test it.
Congratulations! It will make a big difference, enjoy.:)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
7x400 wpc. You went all out bro. You should never need another amp again unless your after different sounds and just testing the water. Congrats on the purchase.Shoot the jumper.....................BALLIN.............!!!!!
This was a fantastic choice. I love these amps. Sunfire Sig will always have a place in my home.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nice buy.
