SDA tweeters
djf
djf Posts: 120
edited August 2010 in Vintage Speakers
Tweeters for SDA's
Anybody know what is the recommendation and availability for tweeters for the original SDA-SRS's?
Post edited by djf on
  • djf
    djf Posts: 120
    edited August 2010
    Nineteen views and no replies?
    Come on, guys, whats the replacements for the SL-2000's?
  • Osarion
    Osarion Posts: 192
    edited August 2010
    The RDO-194 is the replacement for the SL-2000. Call Polk to order them.
  • djf
    djf Posts: 120
    edited August 2010
    Are those the silk dome tweeters?
    I had replaced 6 of the 8 of my SL2000's with the silk dome, but today discovered that two of the silks were shot.
    Fortunately, I had saved the 2000's, so I had replacements.
    Thanks for the reply.
    I'm still amazed these things sound as good as they do! 26 yrs old!
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited August 2010
    WHat did you replace the 6 of the 8 with.
    Don't mix and match. Stick with the RDO-194's. You will be in for a treat. Call polk and tell them you are a club member to the a discount.
  • djf
    djf Posts: 120
    edited August 2010
    I am fairly sure they were the 194's, but don't remember exactly, and there is no number printed on them.
    I did what I could afford at the time. Only recently did I discover two of them (one per speaker) were blown out, so I used the sl2000's, and now have 2 of the silks and 2 of the sl2000's per speaker.
    Sound is bright and tight. As it goes now, I still have 2 sl2000's I could use if I needed to but am thinking about getting the 194's
