Difference between R and Monitor Series?
soverdi
soverdi Posts: 11
edited September 2010 in Speakers
What's the difference aside from their grilles and feet design ? Is this just a marketing gimmick ?
Post edited by soverdi on
  • soverdi
    soverdi Posts: 11
    edited August 2010
    But the prices are pretty close, like for the R50 and Monitor 50.
  • mystik610
    mystik610 Posts: 699
    edited August 2010
    soverdi wrote: »
    The Monitors are a lot better. I've owned both.
    Both of them are discontinued and can regularly be seen heavily discounted, but that my no means indicates that they are of the same quality.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    EndersShadow Posts: 17,722
    edited August 2010
    mystik610 wrote: »
    +1. I ran the R50's in a bedroom setup w/ a CS1 for awhile, sounded good. At the same time I ran Monitor 60's w/ a CS2 in my main rig and it sounded much better.
    Both will play fine with each other, but the Monitor series is a decent step up in terms of overall quality. Thats just my opinion.
  • rooftop59
    rooftop59 Posts: 8,120
    edited August 2010
    I ran r150s as surrounds with a pair of M30s as mains in my first setup, and I agree that the monitors are definitely better, although its not a huge difference. You just don't have good enough components in either line for one to really stand out. Having said that, for around the same price I would definitely do with the monitors. However, if you find the r series for say half price and your budget is really tight, I think that you will still enjoy the r series.
    Peace,
    Paul
    Game Room 5.1.4:
    Bedroom 2.1
    edited August 2010
    Zero is right. But as the lower series go...the R50s are a nice entry into a cheap set of Polk towers and probably have a better low end though the Ms have a bit better mids and highs!
    If you're just starting out you might be happy with a couple R50s--and you can always move them to surround duty when you 'upgrade'?
    cnh
  • soverdi
    soverdi Posts: 11
    I actually downgraded. I miss my Infinity SM-155's :( They were just too bulky and aging.
    I got my R50's last year. Maybe I should make them my surrounds, which I am originally shopping for.
  • Lietuvis91
    Lietuvis91 Posts: 909
    cnh wrote: »
    cnh
    x2 on the above in bold . That is spot on. I had a set of r50s sold them to a friend, got m50's sold those to a friend too... Now I have what's in my sig.
    The r50s sound a bit softer than the m50s and do have better low end. And I personally prefer the look of the r50 1000x over the m50(m50s are just too plain jane for my taste, but of course this is subjective). Non the less, I run an all M series setup in my living room because I find that with a sub, the overall sound is better from the M series speakers.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
