My NAD T765 says to sub out to Left channel. Isn't LFE input better?
nedh84
nedh84 Posts: 143
Shouldn't I use the LFE input instead of the Left/Right input on my PSW 505
HT and Music Rig
Receiver- NAD T765 HD
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Surrounds side- Polk Audio Monitor 60
Sub- Polk Audio PSW505
Windows 7 Media Center
T.V.- 40" Sony Bravia LCD 1080P
Blu-Ray- 80 GB PS3
Post edited by nedh84 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    If you use the LFE, you bypass the PSW505's internal crossover.
    I'd most likely utilize the LFE input since your receiver might have a wider crossover so you can better blend in your sub to your mains.
    If you use the L/R input instead, make sure the cut-off on the sub is at its highest and just use your receiver to set the cut-off or vice versa if you plan on using your subs built-in x-over instead.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • nedh84
    nedh84 Posts: 143
    edited August 2010
    LFE sounds like the easiest option. I was surprised my NAD manual said to input in the Left channel.
    HT and Music Rig
    Blu-Ray- 80 GB PS3
    edited August 2010
    kawizx9r wrote: »
    ..... because if you don't do as Freddy tells it, it will result in double filtering of the sub, not good.
