biwiring & impedence
spr1nt
hey guys,
audio noob here with a couple questions that i couldnt find by searching the forum.
i just bought the csi40 center speaker but im not to sure on how to biwire it. heres the back of my amp.
use speaker wire for #5 split it and connect it to #2 #4. do the same for #6 to #3 and #1. however, i think this is wrong because i shouldnt be leaving out the conections for D right? also which impedence should i pick? i can choose either the top half or the bottom half. my setup is:
main: rti100
center: csi40
rears: fxi30
thx in advance for any help!
main: rti100
center: csi40
rears: fxi30
Post edited by spr1nt on
Connect 2 wires to 5, the other ends connect to 2 & 4. Connect 2 wires to 6 and the other ends to 1 & 3.
Set your switch for 8 ohms.
What exactly is D, is it for a multiroom configuration?
What receiver are you using?
