biwiring & impedence
spr1nt
spr1nt Posts: 1
hey guys,
audio noob here with a couple questions that i couldnt find by searching the forum.
i just bought the csi40 center speaker but im not to sure on how to biwire it. heres the back of my amp.
use speaker wire for #5 split it and connect it to #2 #4. do the same for #6 to #3 and #1. however, i think this is wrong because i shouldnt be leaving out the conections for D right? also which impedence should i pick? i can choose either the top half or the bottom half. my setup is:
main: rti100
center: csi40
rears: fxi30
thx in advance for any help!
  • Frank Z
    Frank Z Posts: 5,860
    edited December 2003
    Connect 2 wires to 5, the other ends connect to 2 & 4. Connect 2 wires to 6 and the other ends to 1 & 3.
    Set your switch for 8 ohms.
    What exactly is D, is it for a multiroom configuration?
    What receiver are you using?
