RTi70 and Monitor 7 V.3
glemay
glemay Posts: 574
edited December 2003 in Speakers
Just wondering but where do you guys think the Polk Audio RTi70 stands compared to the Paradigm Monitor 7 V.3?
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • scornful
    scornful Posts: 272
    I actually like the Paradigm's. Never had the chance to compare them side by side with RTi70's though. If you get the chance take a pair of each home and give em a test drive.
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
    InFocus 4805 ~100" Screen
  • glemay
    glemay Posts: 574
    I have RTi70 and I am happy with them. But I've heard some good things about the Monitor Series from Paradigm, especially if you are in Canada.;)
    Main System:
    Second System:
  • gatemplin
    gatemplin Posts: 1,595
    I have used both the RTi series and the Monitor series (v2 and v3). They are both excellent speakers. The Monitors aren't finished nearly as nicely as the RTis but they are both built very solidly. You cant lose either way but they do have their own sound. It is a matter of which sound you prefer not which is better IMO. Have a listen to the Monitor line when you go listen to the 2200.
    Graham
  • glemay
    glemay Posts: 574
    I will make sure I do that.;)
    Main System:
    Second System:
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Personally, I would take the Monitor 7, but not by leaps and bounds. The 7 is a 2.5 way design, which (imo) results in a little tighter low end, and a little better midrange (ala Polk LSi, but RT remains a 2-way network).
    Problem is, I don't care for ANY of P-dime's matching center channels. I'd rather have a CS300/245/i30.
    Time to get your listen on broham, then report back.
    Cheers,
    Russ
  • glemay
    glemay Posts: 574
    Russman,
    I've got a Paradigm CC-170 V.3 and it seems pretty good for movies. But when playing 5 channel stereo it sounds really enclosed, not open. Is this just the signal that is being sent to speaker from the receiver?
    Last time I was at my dealer I was listening to the Paradigm Phantom V.3 and they sounded very good. Warm sound with fairly decent base and clean sounding treble for the price. I sort of felt disappointed with the performance of my Polk Audio RTi70. And the demo room was much larger than my room. Could something be wrong here or is it just my tastes?
    With the way the Phantoms performed I really expect the Monitor 7 to be something.
    Main System:
    Second System:
