Side Panels on SDA 2Bs Fell off
Assimilator87
When I bought these 2Bs, the previous owner said he took the side panels off to redo the cloth, but wound up not having time so he just glued'em on again. He must've done a crumby job cuz they fell off. What kind of adhesive should I use to get them back on? Any tips or suggestions on the process?
Thanks everyone
Thanks everyone
Polk SDA 2B (Pin/Blade) - Front L/R
Polk SDA CRS+ (Blade/Blade) - Center
Polk Monitor 5B - Rear L/R
Onkyo TX-SR805 - Receiver
Carver TFM-35 - Amplifier Front L/R
12 AWG Monoprice Speaker Wire
Blue Jeans Cable Belden F2 HDMI
Post edited by Assimilator87 on
liquid nails and lay on sides with heavy weights facing up. easy on the glue so it does not squeeze excess out the sides. let dry overnight.
If you EVER want to remove them in the future........nix on the liq. nails idea!:eek: I suggest that you use some very thin gauge brads 5/8" in length to hold them on with. if you carefully "set" them through the cloth, they will be invisible, but the panels will be easy to pry off later.;)
Interesting. I was considering re-clothing my 2Bs and was wondering how to get the side panels off. Guess they are just glued on ... and now I have ideas how to get them back on.
cincycat13 wrote: »Interesting. I was considering re-clothing my 2Bs and was wondering how to get the side panels off. Guess they are just glued on ... and now I have ideas how to get them back on.
another satisfied clubpolk customer:cool: -
i need to redo the sides on mine to. i was gonna use a putty knife to get them off.mole'
Sounds like a plan !:) -
Liquid Nails!!!
Beaver spit! Works wonders on wood even in high humidity environments.
Easily removed for access later.
I like the brad ideas best. Once you glue them down they're pretty much stationary. -
Well they were glued in the first place and still fell off.. and it's not that hard to make new panels..I just tossed the old ones away went to home depot cut some new ones re clothed them and glued them in place with a little liquid nail. you don't need a lot of it to hold them in place...
[IMG]http://www.thecraftbarn.com/shopimages/sections/thumbnails/brads catpic.jpg[/IMG]
Are these what you're talking about? If so, I'm not understanding how they could be used to keep the panels on.Polk SDA 2B (Pin/Blade) - Front L/R
Blue Jeans Cable Belden F2 HDMI -
Have to remove them? the whole idea is to make them stationary so there is no vibration noise. but I suppose if you have a house full of cats, dogs or kids and you have to re-cloth them regularly then you might use this.
http://www.homedepot.com/h_d1/N-5yc1vZ1xhf/R-100153200/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053 -
Assimilator87 wrote: »[IMG]http://www.thecraftbarn.com/shopimages/sections/thumbnails/brads catpic.jpg[/IMG]
Brads are teeny tiny little finish nails.:) -
I wonder what MacGruber/MacGyver would use ?
President of Club Polk -
What about large pieces of velcro?
Do you have a pic of the sides off?________________
2 Channel-Denon AVR-4520/SDA 2.3TL's
5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/ -
BTW is there a name for the cloth? i searched but did not see anything? i need to get some to redo the sides and front of mine.mole'
Grille cloth. Parts express sells it.;)
mole'
Mole,
Buy it from speaker works much better quality IMO. -
TOOLFORLIFEFAN wrote: »Mole,
Thanks. gonna see how much i need and a lil extra just in case i make a BooBoo then order it it.mole' -
i need to redo mine too.. they are peeling off.. and the catz didn't help that ;(PolkFest 2012, who's going>?
danger boy wrote: »i need to redo mine too.. they are peeling off.. and the catz didn't help that ;(
mine were attacked by some cats aswell.
sides and the fronts on both.mole' -
Mine peeled off on their own from the top, and even worse the cloth came unglued. I tried to get the cloth back on but it was hopeless. The side panels were warped so they would not stay on even after regluing. I finally got fed up with them and retired them. They might be a future renovation project. Adding wood sides, and staining the top, bottom, and sides to rosewood would look nice.Lumin X1 file player, Westminster Labs interconnect cable
