Direction of Kimber IC's?
fishbones
I have a set of Kimber PBJ IC's that I've had for years (like 15).
I think at some point and time that they might have had a directional sticker on them saying how to hook them up? If they did, they are no longer there. I have tried switching them around, but couldn't hear a difference.
If someone knows these to be definitely directional, like most IC's, then is there a way to figure it out?
Post edited by fishbones on
If you tried them both ways and could not hear a difference than either way should be fine.
PBJ's are not directional, the drain wire is connected at both ends. I think none of Kimbers IC's are directional...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thank you sir!..... ><////(*>
