Rotel RB-970bx
edited August 2010 in Electronics
I have three rotel amps I recently moved to a new place. I wrapped all three of my amps in a seperate blanket and put them in the back seat. Drove about 30 miles no bumpy roads I unloaded them and hooked everything up and well the RB-970bx would not turn on. I use this amp for my surrounds using a denon avr 3801 as my pre. So I just hooked up the surrounds to the denon. I took the cover off the rotel and noticed 4 fuses 2 in the back 2 in the front. The 2 in the front were blown. What is strange is the RB-970bx was working fine when I unhooked it and have had it for 2 years with pretty much daily use with no problems. I replaced the fuses with the the same value and turned the amp on it came on for a second then the same 2 fuses blew. I looked everything over and dont see anything burnt or dont smell anything. My question is for you electronic gurus what do you think could be causing this and do you think a local shop could repair it. I dont want to spend to much on repairing it as I only paid $250 for it. I dont notice a difference in the sound over the denon. I did notice a difference going from the denon to the rotel on my mains but for the surrounds I cant hear a difference. My plan was to use this amp for a 2 channel sytem I would hate to throw it away. Thanks in advance for any advice.:)
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
Post edited by greg2350 on
Welcome!
    edited April 2009
    Any advice on my problem? I posted this yesterday with no reponses yet:(
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited April 2009
    I would take it to a local shop, and have them look at it. I would look at it for you no problem, but the shipping both ways would be pretty high. A local shop should be able to find a short pretty easy. Also you can replace the fuses with lower amp ones, and turn it on in the dark(cover off), and see if you see the spark. Don't try the fuse trick more than 2 times. You don't want to make a small problem a big problem.
    Ben
    edited April 2009
    My advice is to get a can of compressed air and blow out the inside of the amp really well. Also, loosen the speaker terminals on the back of the amp and blow those off really well, and make sure that there are no teenie tiny frayed speaker wires touching anything, either inside the amp or on the back.
    It's just a guess and kinda a long shot, but if there's a thread of speaker wire inside the amp, that could cause it. If there's contact being made on the back of the amp, it would most likely cause only one side to stop working, but it's definitely worth a try.
    I hope this $5 idea can help you. Please keep us posted.
    edited April 2009
    Thanks guys for the responses I have an air compressor I will try that first the insides look real clean brand new looking. If that doesnt work I will take it to a local shop. A suggestion from another forum was to get a meter and check the rectifiers for a short. Ben If I post a pic could you tell me where the rectifier is? I hope I spelled that right.
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited April 2009
    Component failure is possible. Check between boards and the chassis for burn marks.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
    edited April 2009
    anonymouse wrote: »
    I did have a Rotel with a blown rectifier once and it exhibited the same problem. A rectifier looks like this: http://www.germes-online.com/catalog/87/382/10933/sell_square_bridge_rectifiers.html
    Read this http://answers.yahoo.com/question/index?qid=20070413053442AAlNNB2 on how to test them (the last answer).
    Thanks for the info I checked the rectifier with a meter and its gone dead hopefully I can get another one. Looks easy to replace im pretty good at soldering.
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited April 2009
    Some pics of the broken rotel
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited April 2009
    The one on the left is the bad one isn't it? You can see a melted & arced area in the center.
    edited April 2009
    Yes its the 1 on the left I just replaced it with 1 of the same value and when I turned it on the front 2 fuses blew. I will call rotel monday, again thanks for all you guys help.
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited April 2009
    Mann this sucks I really liked this amp had it for 2 years never pushed it hard sounded great. Hopefully it can be fixed. :(
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited May 2009
    Hey Greg, did you get the amp fixed?
    edited May 2009
    Not yet I have been to busy to mess with it. I have some down time next week I will be looking into getting it fixed.
    AVR: Denon 3801
    Sat: Directtv HD 10
    edited August 2010
    My Dad fixed and upgraded this amp. The original overload problem might have come from different things.. The variable resistor in one channel was shot (fell apart in shipping), so that channel was most likely overloading the supply. One of the transistors in the power supply was not properly attached to the heatsink and its case even changed colour...
    What caused dead bridge and the short? That's what I couldn't figure out, so I gave it to my father. One of the caps underneath the "dead" bridge was physically broken and shorted out. So the whole power supply was shorted and blowing the fuses.
    I replaced all bad components. The power supply caps got a significant upgrade - 4 x 10,000uF industrial grade caps. New industrial-grade ceramic 10% variable trimmer resistors instead of original 20% ones. Fully tuned and singing... I love Rotel sound.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    edited August 2010
    Awesome. Glad to see you were able to get it working. Now someone finally gets to enjoy it:) Sounds like you made it "better than new."
    edited August 2010
    PSOVLSK wrote: »
    I don't know how it sounded new, although I have a Rotel in my HT. I'll post pics of the upgraded board hopefully tomorrow. Thanks for the amp :)
    Oh, yeah, also put modern 10A-rated bridges in the amp. Modern 10A ones are smaller, faster and more efficient than old 8A-rated.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    edited August 2010
    Finally!
    B&W CDM1-SE fronts
    B&W CDM-CNT center
Welcome!
Welcome!
