Great tweak for $8.50
I applied it to my ICs and center channel speaker cable. I plan to apply it to my L/R speaker cables but I am waiting for my MIT cables to come. If I have any left I will apply it to the hdmi cables.
I did notice a more 3D sound coming from the speakers after listening to a few songs. But I generously applied it to the ICS. Half is gone lol.Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables. -
the surround sound effect seems like there is more there now. if that makes sense.mole' -
Wow thats impressive guys. I can't wait til I get a hold of my order.
How long does it take to dry?HT and Music Rig
Receiver- NAD T765 HD
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Surrounds side- Polk Audio Monitor 60
Sub- Polk Audio PSW505
Windows 7 Media Center
T.V.- 40" Sony Bravia LCD 1080P
Blu-Ray- 80 GB PS3 -
i applied it to the ends of the ICs and it looked like it dried right away. just to make sure i let each IC/cable set for a minute or so.
but im not sure if that is the right way to do it.mole' -
It seems like it dried right away in my observation also.
I did the same thing and let the cables sit for a minute before reconnecting.Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables. -
I just realized my banana plugs have unscrew-able tips. I should probably unscrew all of them and apply that stuff on the inside as wellHT and Music Rig
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
I gave some a shot. I'd already applied Caig's, but putting this on the tube pins seemed like it lowered the amount of tube rush I get by 2-3 db. My Holland Aperexes still aren't as quite as the Telefunkens I have (you can't hear them until the volume is higher than you can listen to), but they're a lot closer now.
Put some on the ICs and DIN plug too. Couldn't really tell a huge difference, honestly. But those has also been treated with Caig's previously, and maybe I just haven't noticed yet. Only listened to two of the songs that I use for critical listening, though things did seem just slightly more defined and detailed. I'll go ahead and try some on the mains cables and see what happens and update along with everyone else.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I don't know if I did it correctly but I used a cotton swab. It seemed to dry immediately so I just plugged everything back in as soon as I'm done wiping it. I ended up using half of it. Haven't had a chance to listen though
at first i was also gonna use a cotton swab, but did not wanna get any link or strans of cotton in anything.
maybe i should add some more????mole' -
well the cotton swab soaks up a lot of liquid so that's probably why I ended up using a lot more than you
I think that in the end as long as you have applied at least one layer it all will workHT and Music Rig
This gets my vote as the cheapest and most effective tweak in audio. I heard a wider and deeper soundstage with better microdetail and better sense of envelopment. I wish I'd known about this stuff years ago!
good to hear.mole' -
I am impatiently waiting for my MIT AVt-3 cables so I can get crazy with this stuff! I just want to make sure I cover the new cables with a thick coating then the leftovers go on my hdmi cables.Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
yea i went a little overboard with the coating, but it's so cheap and works so well, why not?
I agree, I will probably have to buy some more. It is cheap and works!Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
same here.........
i think we ordered them on the same day.yea i went a little overboard with the coating, but it's so cheap and works so well, why not?
im gonna do mine againI agree, I will probably have to buy some more. It is cheap and works!
i got 2 tubesmole' -
I hate to say it because I was so excited to receive the product but I really feel like this stuff sucked the life out of my sound. I couldn't stop listening to music every time i went home for the past few days and after putting on that stuff I feel like I lost something valuable in my system. I'm contemplating throwing out all my banana plugs so I can get my system to sound the way it did before I put on the product.
I'm bummed outHT and Music Rig
I'm bummed out
You can try cleaning the connections with alcohol. That might get it off. -
Yeah I'm gonna collect a bunch of those alcohol wipes and try them as they don't leave behind the cotton bits. Thanks for the good idea.
Sucks cause I have to clean the inside of the receivers banana plug inputs.HT and Music Rig
Oh wow that was my 100th post.HT and Music Rig
Alcohol cleaning helped tons. Maybe I just had too much on there. Who knowsHT and Music Rig
Blu-Ray- 80 GB PS3
