The I2S is here,,,,finally
fbm211
fbm211 Posts: 1,488
edited August 2010 in DIY, Mods & Tweaks
And it was worth the wait.
The Prophecy Cryo Silver Reference i2s Digital link cable turns out to be an improvement to the Acoustic zen MC2 AES/EBU cable.And you can be sure the Zen Im using from the transport to Dragon will be replaced too, with thier
Reference AES/EBU cable.
And thier Reference RCA ICs are a new furture contender to try and dethrone my revelation ICs.(Ive tried 6 others including MITs and nothing beats them, although the MITs were close.Just to laid back IMO.)
My gear has come a long way since I joined CP.:D
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    Pics of the i2s...Dig the cool purple.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    So if your running I2S that should effective bypass the CS8412 input reciever in the DAC and it's less than stellar jitter rejection.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    I guess it would.It also bypasses the dejitter section of the dragon so there is less to go through there as well.No need for a dejitter device with i2s.
    Im getting better clarity,and resolution.......Good clean sound.
    Now all I need is a good DC power supply to power the DAC for the best possible SQ.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    fbm211 wrote: »
    What does it have now a wall wart?
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    AC-- IEC inlet.With a rather nice furutech power cord.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    Do you have a schematic?It 's likely the stock supply could be modded to squeeze more performance out of it.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    No, i dont have a schematic.And its not the kind of board Id try to solder.There is a pic posted somewhere.Ill try to find it.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    It can't be any worse than this surface mount board I had the pleasure of modding.:)
