The I2S is here,,,,finally
fbm211
And it was worth the wait.
The Prophecy Cryo Silver Reference i2s Digital link cable turns out to be an improvement to the Acoustic zen MC2 AES/EBU cable.And you can be sure the Zen Im using from the transport to Dragon will be replaced too, with thier
Reference AES/EBU cable.
And thier Reference RCA ICs are a new furture contender to try and dethrone my revelation ICs.(Ive tried 6 others including MITs and nothing beats them, although the MITs were close.Just to laid back IMO.)
My gear has come a long way since I joined CP.:D
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Pics of the i2s...Dig the cool purple.SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
So if your running I2S that should effective bypass the CS8412 input reciever in the DAC and it's less than stellar jitter rejection.
I guess it would.It also bypasses the dejitter section of the dragon so there is less to go through there as well.No need for a dejitter device with i2s.
Im getting better clarity,and resolution.......Good clean sound.
Now all I need is a good DC power supply to power the DAC for the best possible SQ.SDA-2BTL with custom IC
What does it have now a wall wart?Now all I need is a good DC power supply to power the DAC for the best possible SQ. -
AC-- IEC inlet.With a rather nice furutech power cord.SDA-2BTL with custom IC
Do you have a schematic?It 's likely the stock supply could be modded to squeeze more performance out of it.
No, i dont have a schematic.And its not the kind of board Id try to solder.There is a pic posted somewhere.Ill try to find it.SDA-2BTL with custom IC
It can't be any worse than this surface mount board I had the pleasure of modding.:)
