Restaurant Speakers - In-Ceiling?
hank1105
hank1105 Posts: 63
edited December 2003 in Speakers
I posted more or less the same question on another forum. Basically I have a friend that is opening a restaurant and looking for in-ceiling speakers. There are 3 rooms with the same dimensions, 700 square feet with 10 foot ceilings. Can anyone recommend a model of Polk in-ceiling speakers? Don't forget this is for a restaurant, so the music will played at a low level. Thanks for any help.
Hank
My 7.1 System:
Fronts: Polk RTi70's
Center: Polk CSi40
Surround Sides: Polk FXi50's
Surround Backs: Polk RTi38's
Sub: SVS PB1-ISD
Receiver: Sony STR-DA7ES
SAT Receiver: Sony SAT 200B
HDTV: Panasonic CT-36HX42
Post edited by hank1105 on
  • amulford
    amulford Posts: 5,020
    That is alot of space to fill. The only thing that I could think to do would be get in touch with the people at Polk and discuss your problem. Depending on what type of music your playing, you have a few different choices. I beleive that they may even have a couple of comercial products which may interest you.
    Good luck.
  • hank1105
    hank1105 Posts: 63
    Thanks for the reply.
    My 7.1 System:
    Center: Polk CSi40
    Sub: SVS PB1-ISD
  • wallstreet
    wallstreet Posts: 1,405
    any round one will do. you're looking for ambience, not sound quality. and i'd buy more rather than less as you don't want to overpower the poor soul with the seat under one of the two speakers in the whole room.
