Adcom GFR-700
acmf74
acmf74 Posts: 937
edited September 2010 in Electronics
I have the GFR-700 running my complete LSi HT system. It does a fantastic job for HT and music. Would there be any real world advantages on adding on another amplifier? I was thinking of adding on a GFA-555 directly to my fronts (LSi15)
http://www.adcom.com/data/brochures/GFR700HD-SHEET-WEB.pdf
Thanks,
Post edited by acmf74 on
  • acmf74
    acmf74 Posts: 937
    edited August 2010
    OK... one more try.
    My receiver is rated @ 245wpc (4ohm). Now I don't know if that rating is for powering 2 channels or all 5. I was thinking of adding an external amp (GFA-555) to supplement my towers (LSi15). I'm not looking to buy the amp to play at louder volumes because the AVR sounds awesome as is. Any advantages to adding an external amp?
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2010
    Where are you located in Long Island?
    I have an Adcom that I lent out and might be getting back, if I get it soon I'll let you try it sometime on a weekend...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • acmf74
    acmf74 Posts: 937
    I'm still looking for a new amplifier to run my LSi15s. Would a Adcom 5500 be a better choice over a 555? Any advice would be appreciated. Thanks.
  • cfrizz
    cfrizz Posts: 13,415
    Having a seperate amp powering your speakers will almost always sound better than a receiver. Give those LSI's as much power as you can and they will reward you accordingly.
    heiney9 Posts: 25,497
    acmf74 wrote: »
    Thanks,
    Nope, the GFR is a fantastic Home Theater piece. I wouldn't waste the money on adding a GFA 555. You have all the power you need with the GFR700. It's not your typical AVR in that it's power ratings are not inflated.
