SRS2 upgrade
A 5.6 from anyone else would still be in spec."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Soniccraft will make a 5.8uF (or any custom value within the range avail)--I was quoted $14 on the 5.8uF.
I just got through installing mine this weekend. This will be my first cross-over upgrade I have done myself. So far, so good. All I have left to do is mount the 180 uF cap on the cross brace of the cabinets. I found a standard drill will NOT fit in the cabinet!:eek: Will post some pics of the ungodly 180 caps (Solen) later.
stubbySRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2 -
Both Axon and Solen have 91uF caps.
Any known difference in quality?
