Finding leak in left speaker...
Driver_King
Driver_King Posts: 266
edited August 2010 in Vintage Speakers
It always seems like when I think I fix the problem, I've just patched part of the problem. :o I played a 90hz tone through my laptop today and noticed the bass output was virtually non-existent on the left speaker, even though both speakers are level matched. :mad: After doing the PR test, I confirmed that the left speaker is still losing air somewhere. The midrange drivers in the left speaker all have Mortite. I tried playing some other frequencies to see if I could get the speaker to leak air but I really didn't have much luck there. Any suggestions?:confused: Thanks in advance! :)
Home Theater:
Onkyo TX-SR805
Behringer EP2500 for SDA's
Polk SDA II fronts
Polk Monitor 5Jr. surrounds
Polk Monitor 4 back surrounds
DIY A7-900 and DIY A3-300
Post edited by Driver_King on
    F1nut Posts: 51,700
    edited August 2010
    Inspect the rubber surrounds for rips/tears. Inspect the cabinet seams for leaks. Check that the tweeter and PR gaskets are there and in good condition. Remove the Mortite, reinstall the original gaskets and test again. Check that the binding post plate is tight and check that the hotglue type material covers everything on the backside of the binding post plate.
