Rotel rb990bx heating up unevenly
EDUBAG
Hello everybody,
i was just curious that my rotel rb990bx power amp heat more from the right side than the left. It still sounds great and evenly on both speakers (rtia7) but for sure the right side on top of the amp is hotter than the left.
Anybody familiar with rotel could tell me if this is normal, in case it is not what can be the cause and what can be done to fix it.
Regards,
eduardo
Regards,
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
The bias needs adjustment. You can't do it, so take it to an audio tech or send it in to Rotel.Political Correctness'.........defined
President of Club Polk -
Turn it upside down to even out the heat......
Hi Edwardo & everybody on forum ,
i've recently noticed that my loved one power amp Rotel RB-990bx heats up more from the right side as well than the left.
Did you try to fix yrs Edwardo since you had experienced same issue // was the problem a bias adjustment or else ? Is it easy to be done if have a service manual in hand..? (I have it!)
Thanks in advance to all of you that can come up with an answer to my problem..
Regards,
Emmanuel -
Hi dear & thanks for getting back to me.. I might try do it myself.. I have some tools & will read serv.manual..
Lets say suppose has an amp with same issue(bias adj.) but wont notice it so amp stays that way , is that dangerous ?
Best regards,
Emmanuel
Rotel RB990BX
Rotel RB993
Adcom GFA5802
Alexander pream -Tsakirides devices -
Do you happen to have an ultra sensitive digital volt/ohm meter? A pair of mean nothing elcheapo if they blow they blow speakers handy ? Are you comfortable working around high capacitance parts that could actually kill you if you make the wrong move inside a working piece of electronics ?
Hi dear ,
Well , I have some skills on electronics & own some tools .. also a voltmeter but not a digital one.. I should get one..
Those beefy capacitors are rated / 80v 15000mf each ... I will read tech manual & will update..
Thanks for yr attention & advise buddy , much appreciated !!
Advance acoustics mcd II
Mirage OM10
Mirage OM200
Rotel RB990BX
Rotel RB993
Adcom GFA 5802
Alexander preamp
