Question for SDA owners
organ
organ Posts: 4,969
edited December 2003 in Speakers
I noticed that on all the pics I've seen of SDA rigs, the speakers are placed right against the front wall. Is there a reason for doing this? I know why they can't be toed in but don't know why you place them so close to the wall.
Maurice
Post edited by organ on
    F1nut Posts: 51,686
    Bass my friend, bass!
  • organ
    organ Posts: 4,969
    Aaaah:) Thank you my friend.
    Maurice
    F1nut Posts: 51,686
    I should have added that on the later SDA models, they came with a "Bass Brace", which is a threaded bolt. It attaches to the back of the speaker (goes in where the top back bolt is) and then to a wall plate. It is used in place of spikes. I have measured the max. distance to be 18", so perhaps that is why some folks have them close to the back wall. I have mine at 5.5" with the "Bass Brace" installed.
  • Libertyc
    Libertyc Posts: 915
    Hey F1,
    I looked at the rear of my 1.2tls and there is a screw centered 7" from the top. Is for the base brace? Can the bass brace still be purchased? Has anyone made one using all-thread and a pipe bracket? My 1.2 tls sound great but I want to set them up for the best possible sound. I don't have the SDA owners manual, but know in general how to set them up (but not with the bass brace).
  • dorokusai
    dorokusai Posts: 25,576
    Yes, that is it.
    No, it is not sold by Polk anymore.
    I don't know.
    F1nut Posts: 51,686
    Yeah, what Doro said.
    What you need is all-thread the same size as the top bolt and no longer than 18.5", 4 wing nuts (2 for each rod) and some sort of bracket that you can screw into the wall with a threaded hole for the all-thread. Spray it all satin black and you're set.
    Set up should be at least 6' apart (inside edge to inside edge), no toe-in and at least 3' from any side wall.
    If you've got anymore questions, fire away.
    I forgot to mention that if you want to build the AI-1 interconnect (I don't think Har is with us anymore), I have a copy of the plans. Send me your email addy and I'll get them to you.
  • i4gotmyid
    i4gotmyid Posts: 173
    http://www.cardas.com/cgi-bin/main_content.cgi?area=Insights&content_id=26&pagestring=Room+Setup
    Or you can try this, i did this with my room setup, my wife was kind enough to let me put my speakers 6 feet into the room. As long as you make a triangle with your setting you get solid deep extension that sounds awesome.
  • hotwheelman
    hotwheelman Posts: 1,300
    Never mind.
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
