E8400 wolfdale users.
fbm211
Whats your temps.
Im getting readings at 44c-(core0) and (49c-core1.)
This is with a zlaman copper heatsink.CNPS9800 I think.
Are these temps safe?
My PC isnt 100% stable....games just quit.IE locks up
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Had an E8400 2 years ago, ran I think it was...39-41c and up to 45-49c full load using a Thermaltake heatsink. I remember that much cause I never saw past 51-53c. It was my gaming computer.
Did you OC yours at all?
I OC'd mine, upped the voltage as well as changed the timing on my memory and OC'd my video cards.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Those are my idle tempsSDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
What paste did you use when you installed the Zalman, and how much of it?
FWIW, i've never been a fan of those Zalman heatsinks, but i don't think it should be the problem, here. Sounds like the install may have been botched.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Ouch, bet you already know this but keep in mind regardless of how many fans you've got in your PC...it's taking air from within the room you're in so that could be a factor as well to consider. I had a small AC in the room I was in.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
concealer404 wrote: »What paste did you use when you installed the Zalman, and how much of it?
Good point Ben!
Btw, 6k posts? God damn :eek:Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
I have AC.
I think concealer404 is on the right track.
I used zalman paste.Just a bit on the sink and a bit on the cpu like always.Never had this problem before.
Its time to order some more artic sliver 5 like I always used before.I need a new mouse anyway.SDA-2BTL with custom IC
Good point Ben!
I HAVE been here for twice as long as you, you know.
I've been slowing down a bit, though. I'm at a wierd crossroads where i have no idea where to go with my rig. It's partially your fault for taking "my" Paradigms.
I'll pick back up when Chris brings me teh new hawtness.
concealer404 wrote: »I HAVE been here for twice as long as you, you know.
Lol true, that and I had that sudden 'absence' from the forum.
Hey, I always told ya the Paradigms are simply waiting in my rig until you've got a chance to take them! I plan on returning back to Magnepan speakers anyway so whenever you can swing it let me know! Got the original boxes and everything.
And good call FBM, I've never used Zalman or any other paste for that matter other than the Artic stuff.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
I have AC.
When you say "a bit," how much do you mean?
Is the zalman stuff copper, silicone, or silver based? Silicone paste is a waste of time, and i don't like the copper, either.
Order some AS5, make very sure you get both the heatsink and the cores squeeky clean before you install again. Then, on the CORES ONLY, put a small bit of AS5, think like... small grain of rice. Then install heatsink.
I always did a "no-no" and would spread the paste evenly with a credit card over the heatsink with great results in performance, but common wisdom says NOT to do that, so i'd stick with that.
That said, i DID manage to get my old AMD Athlons to idle at dead room temp using that method back when i was into overclocking. (Yes, still on air cooling.)I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Oh, i'll be taking them, then.
I still need to call you, (and chris for that matter) just been stupid busy. Lots of news and stuff.
Those temps aren't too high. I have a E8400 running at 3.8Ghz, temps are 43c and 39c at idle, but I've seen them both go to 50c when encoding, I use an aftermarket heatsink, forget the manufacturer. Computer has never crashed in two years.
I've seen E8400's with stock heatsinks at work run 50c all day long without an issue. Looks like a software issue to me, or maybe a buggy motherboard. -
concealer404 wrote: »Oh, i'll be taking them, then.
Yeah same, currently in Texas...and that PT Cruiser GT is an automatic. The turbo in it makes the car fun. Tell you all about it later.
FBM, what kind of mouse are you getting? Got me missing my older E8400. Was running Corsair XMS2 ram with dual 8800 GTS SLi'd.
Dual boot, XP as my main and Ubuntu as my alt but I'd run both anyway (Ubuntu on virtual machine) with dual monitors. Now I run an AMD with a 5750 also on dual monitors (Vista and Fedora mainly but sometimes Ubuntu) on my main computer.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Ah... i didn't know what the temps of those things were supposed to be. Just sounded way high from what i'm used to.
Might be time to run some memory tests.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I have some AS5 but its over 2 years old and has been used twice.---Too old.
The zalman stuff is white and I would have to say that after this I will never use anything but AS5 again.Maybe Ill get some of that AS cleaner too.
This rebuild went perfect except for the thermal problem.And I need a CPU power cable extension.
ThanksSDA-2BTL with custom IC
Does AS5 have a shelf life? I still have some from like... 5 years ago that i used a couple weeks ago on a laptop that was overheating.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I think Ill get a RAZER diomondback or Copperhead.:D And mouse pad too.
Im going to reinstall XP again..Dont want to blow too much money as I plan to go to an i7 platform in a few months.Ill set up a dual boot with XP for gaming my current games and win 7 for internet and the games coming out soon.---Like Need for speed coming out in november.:D
I read on newegg somewhere to use fresh thermal paste.Its probably still good though.Ill have to look in the old parts box for it.SDA-2BTL with custom IC
Make sure to look into the model you plan to get, I heard some of them can run a bit warm and they're of mediocre build quality. I've always stuck with Logitech
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
I
Razer mice. I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Does AS5 have a shelf life? I still have some from like... 5 years ago that i used a couple weeks ago on a laptop that was overheating.
I don't think so. I still have some AS3 I've been using for at least 8 years, works as well as it ever did. -
running a Xigmatek 1283 I was getting idle temps around 30 degrees and full load video encoding at 55 or so. I changed some things up and am now using a little Rosewill Z300 cooler (basically a simple stock replacement, using the Xigmatek in a different machine), and it is idle around 35 degrees. No overclock.
Pentium E6300 (Wolfdale) @ 3.5GHz (turned down for the summer)
47-49C at 100% load with ~27C ambient.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Your temps are fine.
At stock speeds, Intel Core CPUs are happy as long as you keep them under 70C. The actual spec that Intel gives is 72.4C, but I'd be a little worried at anything above 65C though.
My Q9550 with a older Zalman flower type cooler and Arctic Silver generally runs around 44-48C at idle on core 1 (environment is usually around 25C). I see 55-58C under heavy encoding loads. The other cores tend to run a few degrees cooler. I've had absolutely no stability issues.
BTW, I wouldn't worry about your AS5 being too old. The stuff is basically very fine silver particles emulsified in an oil paste. How does that go bad? You should make sure you followed the most current Arctic Silver directions for your CPU. They vary a lot depending on the core arrangement, etc. -
The fans I ordered for the top of the case got here today and the DEMCiflex Computer Air Filters will be here next week.
Best of all I got a 4c temp drop.49 down to 45.:DSDA-2BTL with custom IC
Niiice.
I'd like to hear about your CPU once you reapply the thermal paste between it and the heatsink.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
The AS5 should be here monday.
Id like to OC it.Ive been getting my read on P35-DS4 OCing and a-lot of people get this set-up to 4GHZ----Easy.SDA-2BTL with custom IC
This is a link to the heat sink and fan I use. You can get it now and use it. When you buy your i7 you'll be able to use it with it,as it comes with mounting hardware fot LGA775, socket 1156 and socket 1366 cpus. It also comes with mounting hardware for AMD sockets as well.
http://www.overclockersclub.com/reviews/noctua_nhd14/"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I have an 8400 running at just under 4 GHz using a Corsair H50 liquid cooling setup. My idle temps are very close to yours but even under load I rarely see variations of more than 5 degrees. Also rock solid. No crashes. Ever. Here's a link:
http://www.corsair.com/products/h50/default.aspxSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Would DDR 2 memory run on DDR3 mobo.For instance this one.>> http://www.newegg.com/Product/Product.aspx?Item=N82E16813128422.SDA-2BTL with custom IC
No, DDR2 memory will not work on that board."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
DDR2 memory is NOT pin-compatible. While both have 240 pins, there's a notch that simply won't fit in the wrong type of slot.
Another option for you might be going the AMD route. If you've already got 240-pin DDR2 667+ DIMMs (ie: desktop RAM, not 200-pin laptop RAM), you can get away with saving $50+ (for me, more like $120-150) by going with an AMD AM2+ motherboard that uses DDR2.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186149 or http://www.newegg.com/Product/Product.aspx?Item=N82E16813130266
And, for a processor, http://www.newegg.com/Product/Product.aspx?Item=N82E16819103809 or http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851
You'll also want to make sure that your power supply is good enough for the load. A $20 unit simply won't cut it long-term. If you're only planning on running stock (not overclocking), then a power supply such as a Corsair 400CX, Seasonic SS-400ET Bronze, or Antec EA-380D or EA-430D would be great choices.
On a side-note: a Wolfdale processor WILL NOT WORK in an LGA-1366, LGA-1156, or AM2/AM2+/AM3 motherboard. They'll only work in LGA-775 motherboards which have long since been EOL'd (discontinued).polkaudio Monitor 5 Series II
